Timing Belt tensioner bolt wont move.
Old Jun 1, 2011 | 09:17 PM
Mad-Mike's Avatar
Default Timing Belt tensioner bolt wont move.
I need to loosen the timing belt to get it back on the cams but for some reason the timing belt tensioner will not move. I am afraid that I am going to break it. How tight should these be and how easy is it to break one?
Old Jun 1, 2011 | 09:44 PM
PyroProblem's Avatar
Default Re: Timing Belt tensioner bolt wont move.
Did you loosen it to remove the cams?
What kinda engine are we talking about here?
Its pretty hard to break one.
Old Jun 2, 2011 | 08:07 AM
Mad-Mike's Avatar
Its a b18b1, I slid the timing belt off and now I am trying to loosen it to get it back on.
Old Jun 2, 2011 | 06:36 PM
You did loosen the bolt right?
Old Jun 2, 2011 | 06:56 PM
Mad-Mike's Avatar
I didn't try it out yet. I was told that I would need a breaker bar to help get it out. But we been pretty successful on sliding the belt back on but once we get the belt on its always off by a tooth! I can't find out where to put the allen keys in the cams. Gonna give it another go tomorrow give it another look at.
Old Jun 2, 2011 | 07:17 PM
mikesrex's Avatar
if you don't want to break it loose just put the cams in time and the belt on before you tighten the cam caps. It's kinda ghetto but works. If you do try to break the bolt loose, you might want to make sure you have a 6-point socket instead of a 12.
Old Jun 2, 2011 | 07:30 PM
You dont need to take the bolt out all the way, just loosen it a little. Ive never tried to replace cams without loosening the belt first.
Old Jun 2, 2011 | 07:35 PM
Mad-Mike's Avatar
Thanks for the tips. I'm gonna check it out tomorrow and see what happens. I just wanna get this dam timing correct!
ill fast
13
Nov 21, 2011 04:43 AM
j87w
Aug 15, 2005 12:07 AM
bOOsTiNSoHcVtEc
Aug 5, 2005 09:28 AM
InTeGrA B18b1
Aug 20, 2003 07:57 AM
baonest1
Jun 10, 2003 04:03 PM
