93 Civic DX - need help identifying cut wires in steering column
Old Jun 1, 2011 | 09:11 PM
cloudconnected85's Avatar
Default 93 Civic DX - need help identifying cut wires in steering column
93 civic dx
The wires are located along with the ignition wires in the steering column. They are separated inside their own sleeve they are two identical wires, blue with white stripes.
I ask due to finding them under the column cover cut and hanging loosely next to the ignition switch.
Old Jun 1, 2011 | 09:16 PM
NOFX's Avatar
H-T White Ops
Default Re: need help identifying wires
Originally Posted by cloudconnected85
93 civic dx
If a '93 Civic is at all like my '88 CRX, it's to the key-in reminder, which mounts to the bottom of the tumbler right next to where you insert the key. The part that mounts to the tumbler is a black square of plastic.
Old Jun 1, 2011 | 10:11 PM
Default Re: 93 Civic DX - need help identifying cut wires in steering column
That was it. Thank you, was not thinking about the key chime.
Old Jun 1, 2011 | 10:29 PM
NOFX's Avatar
H-T White Ops
Sweet! I wasn't 100% sure. I just happened to swap the ignition switch (with wiring) in my CRX so I just remembered from doing that about half an hour before I saw your question.
Glad to have been able to help.
VN712
Aug 19, 2007 12:56 PM
hyperlife70
Jun 18, 2007 09:43 AM
