Transmission & Drivetrain Gearboxes, Differentials, Clutches
whinning noise on 1st and reverse NEED HELP!!!
Old Jun 1, 2011 | 07:03 PM
jhojhet's Avatar
Default whinning noise on 1st and reverse NEED HELP!!!
Hello every one,
I just finished my B18 swap to my EK replaced Stage 4 CC and flywheel and replace the axcle as well.
There is a bit chattering the on the cluctch on 1st gear and during this clutch chattering there is a weird squicking noise like and exhaust pipe rubbing on the body of the car.
I check all piping and could not see anything close to that may rub on my exhaust.
I checked all over the engine bay and under the car could not seem to find where the noise is coming from.
It seems to be coming on the passenger side front or under the car since it's more louder when i put the passenger window down on that side.
Does anyone experience this and found it?
I'm suspecting it coming from my tranny as well since this only happens when you fully pressed on the clutch and slowly moving the car on 1st gear. It kinda long noise if you hang on the cluctch on the middle causing the car to hal engage.
Thanks for your help...
Old Jun 5, 2011 | 08:37 PM
jhojhet's Avatar
Default Re: whinning noise on 1st and reverse NEED HELP!!!
here's the video link;
http://www.youtube.com/watch?v=q3nwAXWLyV4
Old Jun 10, 2011 | 03:20 AM
N/A's Avatar
N/A
Purpose Built
U check your fluid?
Old Jun 27, 2011 | 10:05 PM
spoonhatchblack's Avatar
Did you ever find out what is was?
Old Jul 14, 2011 | 07:59 PM
jhojhet's Avatar
NO. i dont seems to see where is coming from.
I search and search and final conclusion would be my clutch.
i will break it in and see what happens from there. It's really annoiying every time i stop and go.
mychdb2gsr
Jun 7, 2011 04:15 AM
EG-evokilla
21
Apr 1, 2009 07:34 AM
Naboost
Honda S2000
10
Oct 27, 2008 07:57 AM
azteggi
Jan 5, 2005 02:53 PM
