How much are your b20v builds costing you guys to build?
Like the title states. How much are your guys b20v cost to build including tune and how much whp it putt out.
I just kinda did a quick list down and at the end my b20v will cost me $5-6K and im still missing engine mounts and fuel pump and filter.
already have:
b20b block-70
ls crank micropolished/balanced, cp 84.5mm 12.5CR pistons,eagle rods as a combo for 550
alaniz Pnp b16 head-400
supertech exhaust flatface valves-50 new
oem itr intake valves- ~120
cp rings-100
arp head studs-100
aem ems-500
PLM v2 header 350
aem fuel rail new-50
total-2290$
still have to get:
clutch- ~400
id1000cc injectors for e85-500
cams- 500-700
machine work/balancing etc-500ish
blackworks vtec kit-100
oil pump/water pump-150ish
headgasket-100
bearings- oem 300 or acl 120
b16 vic x IM 300
and most important tune- 400
total- $3100
Thanks
And here is my build page that i started in May OF 2010.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/my-allmotor-b20vtec-12-8-13-0cr-e85-build-2770837/
already have:
b20b block-70
cp rings-100
arp head studs-100
aem ems-500
PLM v2 header 350
total-2290$
still have to get:
clutch- ~400
cams- 500-700
headgasket-100
b16 vic x IM 300
total- $3100
Thanks
So no one is going to share the total amount of $ invested into building a b20v from scratch?
buy a set of arp rod bolts and get the stock pistons machined with bigger valve reliefs. rebuild the bottom end with stock parts and throw a b16/b17/b18c1/5 head on it
head 400
block 200 + 400(for rebuild)
arp rod bolts 100
machine work 200
gaskets and timing belt 200
so around 1500 i would think would get a stock reliable b20V
head 400
arp rod bolts 100
machine work 200
Thats why you buy someone elses unfinished project when ppl run out of $$ now-a-days.
Couple weeks ago sold:
95gsr with b20v built. I know for sure he had s2s2 cams and he claims 11.5:1 pistons. He needed headers, injectors and something elso minor. Do a motor tear down and put everything together so you are sure what you have. Integra pretty clean. Sold for $4600. And thats with the car so thats steal.
Another deal I fricken missed: 98gsr build my midnight. Over 220whp. Posted for $1500. I thought spam but not. Needed bail out $$ fast. I called and it was sold.
Just dropped off my EM1 off at the shop, but here are the mods:
BUILT BY SPEEDFACTORY RACING
USDM long block
Bore and honed to 84.5mm
RS machine 84.5mm type are spec pistons
polished crankshaft
b18c1 full port and polished head with performance valve grind
oem gsr water pump
oem gsr oil pump
oem gsr timing belt
obd2-obd1 wiring harness
skunk2 pro series duel valve springs
skunk2 valve train
skunk2 pro3 camshafts
golden eagle camgears
ssr street sweeper replica large tube headers with 3" outlet
custom 3" straight through exhaust system
edelbrock victor x intake mani port match to head and tb
omni power 68mm tb
precision 580cc injectors
acl thrust washers
acl standard rod bearings
acl main bearings
Custom speedfactory racings oil catch can
competition stage 2 clutch and flywheel
mfactory helical lsd
walbro hp255 fuel pump
Chrome chipped p28, will be switching to hondata s300 within a month or two.
i know im missing a lot more, ill be getting it back within a week or two ill post dynos ect..... so far around 8g's, not including all the misc. stuff. all the little stuff adds up, but before you say i could of went k series, if you dont got it then dont speak. still at the shop but you get the idea here's some pics at the shop.
lil pic of the interior
USDM long block
polished crankshaft
oem gsr water pump
oem gsr oil pump
oem gsr timing belt
skunk2 valve train
omni power 68mm tb
acl thrust washers
acl main bearings
That's because you're looking at people who get turbos that are too big for their application, with the belief that they want to grow for more power later.
The average build can range from $3K to as high as $7K depending upon where they get their balancing and machining work done. This may or may not include hard-parts such as cranks, crank pulleys, balancers, tensioners, etc that you may have.
Many people don't find it the most relevant to post the price tag of what they've paid 1) because it reminds them of what other things the money could be spent on other than an engine, and 2) the cost varies so much due to the availability of things that it never remains the same.
But based upon the average, of about $4000-$6000 or so, you're right on target if you're worried about whether or not you've paid enough to get this together.
head 400
arp rod bolts 100
machine work 200
head 400
arp rod bolts 100
machine work 200
X2
Thanks
yes i read the post but you asked how much it costs US to build OURS. not how much your should cost. .
so i told you how much a simple b20v should cost you to build from scratch
USDM long block
polished crankshaft
oem gsr water pump
oem gsr oil pump
oem gsr timing belt
skunk2 valve train
omni power 68mm tb
acl thrust washers
acl main bearings
USDM long block
polished crankshaft
oem gsr water pump
oem gsr oil pump
oem gsr timing belt
skunk2 valve train
omni power 68mm tb
acl thrust washers
acl main bearings
Good luck to you. Post up some graphs once you get her tuned.
4,500 +- and if you want a transmission to match you are looking at another 1500. A matched setup is going to cost you but be fun in the end.
Yeah and its someone else's build. not mines. And i see were your going with this butt no. I already have a solid chassis to build of. And tough luck for missing those so called deals out. You have a perfect car to build of from so why even waste your time/money on another car. Built not bought like they say.
Just look.... your build ~6k + 2.5k(your car) - ~1.4k(if you sell the gsr motor) = ~7k. Now thats without paint and R front.
Why waste time/ money? I paid 3.5k and I could add a couple more k and buy a ready to go teggy with new paint job and R front. I will spend way more if I start from my car.
I'm building a project b20vtec on my spare time right now.. so far it has cost me about $1300..
B20b short block- Free
JE 12.5 CR pistons
OEM honda bearings and thrust washers
OEM LS rods modified with arp rod bolts
OBD2 gsr oil pump, waterpump, and timing belt
CTR crank pulley
GSR head with CTR cams and supertech valvetrain I had laying around from a parts car
GE 84.5mm headgasket
ARP headstuds
ITR trans
Granted a lot of the parts I already had or got for extremely cheap, most of the money went into just building the short block.
JE 12.5 CR pistons
CTR crank pulley
ARP headstuds
ITR trans
JE 12.5 CR pistons
CTR crank pulley
ARP headstuds
ITR trans
JE 12.5 CR pistons
CTR crank pulley
ARP headstuds
ITR trans
Thanks
