5 lug swap
Take your stock hubs out, then remove the OEM studs and have the holes filled in and welded solid.
Then get the hole locations off the 5th gen and have them properly drilled on your OEM hubs that have been welded shut and then replace the hubs.
You now have a 5 lug conversion. That is pretty much the long and short of it.
Its been done.
Its been done.
bro i would advise you not to do it i have a 2000 prelude with 5lugs and when i was looking for rims it was a pain in the *** every thing i liked was all in 4 lug i was wishing i had a 4 lug car at the time same goes for the last car i had...
jaypain
Feb 24, 2022 06:47 PM
