Demon or ecu damage to pin j1?
Old Jun 1, 2011 | 01:27 PM
b20ricepower's Avatar
Default Demon or ecu damage to pin j1?
ok, so i've had my ecu chipped and running on crome for about a year now no problems. I decided to switch to neptune while i also went to a vtec setup. At first when i installed the demon, it seemed to be working ok. It would read the base code fine and all sensors seemed to datalog correctly. Then all of a sudden it just stopped datalogging altogether. It says connected but recieves no data from sensors. So i took off the demon to inspect it and noticed that the j1 jumper on the ecu touched the demon board. It left a little electrical burn mark on the demon but no other visible damage. With the demon unplugged or plugged in to the ecu, i can confirm that it receives the base code fine but it wont datalog. Doesnt seem as if the ecu knows that the demon board is there. I can start the car for a second with the demon unplugged which is really weird too. Kinda like its trying to run off the stock chip. It does the same thing when the demon is installed as well, it will run off the stock map it seems. Could j1 have possibly been damaged and thats why its not seeing the demon
Old Jun 1, 2011 | 01:40 PM
Default Re: Demon or ecu damage to pin j1?
Btw, from what ive read, j1 doesnt get power it just acts as a jumper to switch the secondary chip area on. So if j1 isnt jumped then it will read the stock chip only. Could power from the ecu via the demon have grounded through j1 and burned it up The jumper itself looks fine.
Old Jun 2, 2011 | 05:19 PM
No one huh
Old Jun 2, 2011 | 06:54 PM
q16racer's Avatar
support@hrtuning.com
Old Jun 4, 2011 | 02:53 PM
Yea he basically didnt give me any technical info. Just said to send it in to have it checked
Old Jun 4, 2011 | 03:00 PM
q16racer's Avatar
thats all he can do.
swamp_ass
Engine Management and Tuning
Mar 6, 2018 04:48 PM
Preludepradit
Jun 3, 2008 06:05 PM
Hybridize
Oct 19, 2003 05:10 PM
kim_2_da_chee
May 30, 2003 06:18 PM
racerxadam
Jan 13, 2002 08:37 PM
