'97 EK Sedan thinking about selling.. NO 56K
I have a '97 EK Silver Sedan with no body damage, no rust, 43K miles, AUTO.
This car was in Cali until 2004 when it came to Michigan and driven by a grandma; she had everything that the dealership recommended done. Including a new transmission @ 30K miles for $2800!
The car has one ding on the hood, four scratches (one on the trunk lid, two on the front bumper, and one on the rear bumper), also there's a burn hole in the seat.. but the car doesn't smell of smoke.
Thinking about getting an Apexi WS2 system, Skunk2 coilovers, Strut tower brace, and aluminum rear lower control arms.
Upgrades/maintenance documented in the last 10K:
- Oil pan re-sealing.
- Two 4-wheel alignments.
- Several wheel balances. (Free from discount tire.)
- Countless (touchless) car washes, interior cleanings, vacuumings, and a hand wax.
- DDM Tuning 35w BiXenon HID kit with separate harness.
- V-LED Type 2 60SMD Switchback bulbs with 15ohm resistors.
- LED License plate, interior, reverse, and 3rd brake light bulbs.
- JDM CTR Style black housing amber delete headlight housings.
- Si OEM style amber delete tail lights.
- WeatherTech floor mats. (Has stock carpeted ones too.)
- Dual XHD-7714 Headunit with HD radio, XM ready, CD, USB, tagging, 3.5mm, etc.
- Power steering fluid DIY flush @ 43K.
- Valve adjustment DIY @ 39K (New top-end gaskets.)
- Trans fluid drain/refill @ 43K. (Trans had 13K miles, I was just bored.)
- Two new Bosch O2 sensors planer, better. (Upstream and downstream, again bored.)
- New Bosch dizzy cap and rotor with gasket and bolts.
- Airtex copper plug wires.
- NGK Platinum plugs.
- Heat shield fix.
- Five oil changes with Royal Purple 5w30 and Bosch Prem. filters.
- Brand new SE Fox2 14" lightweight alloy rims with Falken Ziex ZE-512 tires for summer. (Tires come with 4 replacement certificates.)
- New set of steelies with Blizzaks before last winter.
- Bosch fuel filter.
- AEM SRI w/ DryFlow.
- WeatherTech Fitted car cover. (For when I have to leave it outside when I go on trips.)
Also has the original window sticker, manual, SRS book, everything.
Pics below, just wondering what you think I could get for it.. KBB says about $5,500.
I'll get pics of it with the new alloy rims/tires.
- Heat shield fix.
