how to install toda b cams
Old Sep 30, 2002 | 06:22 PM
514_type R's Avatar
Default how to install toda b cams
Is it complicated to install toda b spec cams, is it like a normal type r cams??.....what is the 0.20mm cold valves adjstment.
will a acura mechanic know's how to install the cams from the toda spec sheet, found in the box?
thanks
Old Sep 30, 2002 | 06:34 PM
BABY NSX's Avatar
Default Re: how to install toda b cams (514_type R)
Not the simplest cam to install because you NEED to change the valve springs.
Old Sep 30, 2002 | 06:36 PM
Dave-ROR's Avatar
remove old cams
install new cams
that's technically all there is to installing the cams themselves..
JPP's Avatar
JPP
No it is not very complicated to install spec B camshaft. A good mechanic with Honda engine knowledge should be able to do it without problem.
The 0.2mm is the rocker arm to cam lob clearance needed for the spec B to perform correctly, the mechanic would need to readjust all the valves with this spec.
Old Sep 30, 2002 | 06:39 PM
D's Avatar
D
Default Re: how to install toda b cams (BABY NSX)
NEED? can you be a little clearer?
Old Sep 30, 2002 | 06:40 PM
Dave-ROR's Avatar
Default Re: how to install toda b cams (D)
well if you don't, the timing belt will shatter into approx. 4.5834432496743245 billion pieces, the cams will break into 5 pieces and the pistons will slam through the head, valve cover and hood.
Old Sep 30, 2002 | 06:43 PM
D's Avatar
D
Default Re: how to install toda b cams (Dave-ROR)
oh chit. we're fuct! ALL DONE!
Old Sep 30, 2002 | 06:47 PM
Dave-ROR's Avatar
yep, it's the big secret all the toda guys never wanted anyone to know.
You just can't trust those toda fellas.
Old Sep 30, 2002 | 06:57 PM
BABY NSX's Avatar
No... that is as clear as I can be
Old Sep 30, 2002 | 07:06 PM
Eric R's Avatar
Spect B's need higher pressure valve springs compared to stock ones. This way your valves won't float at high rpm and it is the only way you can make more power at higher rpm as well. That's why the install of B's are a lil more complicated and longer. Also, it is recommended to install a reinforced timing belt for reliability purposes.
Old Sep 30, 2002 | 07:12 PM
514_type R's Avatar
Default Re: how to install toda b cams (JPP)
thanks, if I ask the the acura mecanic to do a 0.2mm valve adj, will he understand??
Since My head was already refaced so milled a little will he have to put a 0.19mm valve clearence if my head was milles like 0.1mm.
Once the head is pulled are the valvesprings installation hard or long??
they have to install new piston rings anyways, do you think they will mind installing the toda stuff, they have to remove the cams and camgears anyways, and since the head is out the valvesprings install will not take much longer, what do you guys think?? How much does a valve adj cost at acura??
by the way thanks for the previous reply
Old Sep 30, 2002 | 07:19 PM
D's Avatar
D
uh, NO.
the hard and long thing, i could comment on, but managed not to.
Old Sep 30, 2002 | 07:20 PM
sneakychaos's Avatar
He should. If he doesn't, just tell them that instead of resetting the valve "lash" to stock, please set the valve lash to .2mm
You're talking two different things.
Not with a valvespring tool, but having someone experienced doing the work is a plus. Need to be very careful with spring/retainer/keeper install, and making sure you don't bend the valve while your doing it.
Why do they need to install new piston rings? If you have to have the block pulled, you mind as well have new pistons put in to raise the compression. You will see more gains with the Spec B's on a higher compression ratio then you will on the stock. People seem to prefer 11.5:1 to 12:1, whereas the stock compression is 10.6:1.
Old Sep 30, 2002 | 07:21 PM
Ditto.
Old Sep 30, 2002 | 07:31 PM
Splat's Avatar
Collector-o-Guns and Drinker
INCORRECT
My STOCK valvesprings and retainers were perfectly happy with the lumpy Toda B joy. As long as you retain the stock rev limiter, and don't beat it on a daily basis, you will be fine with STOCK Type R valvetrain.
Now, B16 or GS-R valvetrain should definitely be upgraded. But Type R valvetrain will hold B's just fine.
Old Sep 30, 2002 | 07:37 PM
Default Re: how to install toda b cams (Splat)
INCORRECT, too y0
I beat on mine daily. Ran just peachy. Stock valvetrain, stock ECU, stock timing belt.
Old Sep 30, 2002 | 07:52 PM
514_type R's Avatar
Default Re: how to install toda b cams (trooth)
ok, thank you very much trooth
I will most likely not changed my piston now, I dont have enough cash right now, I also have to get the hondata s200 in the first week of install, piston might come later.
My CR is raised a little since my head was refaced. How his he(the mechanic) supposed to calculate if my head milled will not affect the clerance of the cams??
ok, thanks, I will ask for either a valve adj or lach of 0.2mm
as for the valve springs installation, I believe a acura dealer know how to install valvesprings without bending the valves
Old Sep 30, 2002 | 07:59 PM
514_type R's Avatar
[/QUOTE]Why do they need to install new piston rings? If you have to have the block pulled, you mind as well have new pistons put in to raise the compression. You will see more gains with the Spec B's on a higher compression ratio then you will on the stock. People seem to prefer 11.5:1 to 12:1, whereas the stock compression is 10.6:1.[/QUOTE]
because my car is burning oil like a ****
Im presently dooing an oil test and in 1600km(approx 1000miles) they had to add 1 liter the first time and 1-2/3 liter the second time, its almost 2 liter oil burned oil in 1000miles+ its my mom who drive the R during the week since I take the bus for university.... my mom is 51yo and she do not hit vtec, therefore my car is burning oil even under easy everyday driving
Old Sep 30, 2002 | 08:13 PM
Splat's Avatar
INCORRECT, too y0
Then j00 have deeper pockets than I
I kept out of the limiter just for extra safety. Stock ECU, stock valvetrain, stock timing belt, stock cat-back. Power dropped off after 8200 anyway
Old Sep 30, 2002 | 08:28 PM
EPGONZALEZ's Avatar
make sure and torque down well...to todas specs(call them and ask them what they should be) and make sure you get there special cam gear bolt..
mine broke after less than 20 seconds of idling..
i was using the springs, belt and toda cam gears..
they say its an installation error..but i believe they are just back peddaling
Old Sep 30, 2002 | 08:49 PM
Splat's Avatar
Default Re: how to install toda b cams (EPGONZALEZ)
What broke? Cams? Gears? Belt?
"Special" bolt = longer cam gear bolt because the Toda gear has a thicker-than-stock center section. Just to avoid confusion.
Old Sep 30, 2002 | 08:53 PM
EPGONZALEZ's Avatar
the cam broke...right were the bolt would end in the camshaft..
im no metalurgist (sp?) but they do not look billet at all
Old Oct 1, 2002 | 07:50 AM
514_type R's Avatar
bump to the top
post your passed experience
Old Oct 1, 2002 | 07:51 AM
AssPenny's Avatar
Dunno... getting them installed this weekend Yack tuned.. i hope...
And I did go for the springs and the pe belt... only think i can not afford at this time is the aem ems Oh well x-mas is coming up, now i just need to find a rich gf
Old Oct 1, 2002 | 08:15 AM
Hooch'n's Avatar
Default Re: how to install toda b cams (AssPenny)
word!
