95 Accord Trans Fluid
Like the title says, im in the middle of a swap, stock F22B1 replaced with JDM F22. All of the trans fluid drained out while removing the motor so I wanted to know where the fill hole is.
Its a manual trans.
Its a manual trans.
There is a fill and a drain plug on the transmission. Little reference video.
The fill hole on the manual transmission should be up about halfway on the bell housing on the left (towards the interior) side of the transmission. It is another one of the ratchet bolts. You will have to use a tube with the funnel to get it in there.
Alright I know what you guys are talking about...same as on a D series i did a swap on a while ago.
I have the engine/trans up in the air on the hoist right now, i loosened most of the trans bolts and half shaft.
uberEFtuner
Jan 31, 2011 06:34 AM
GoLowDrew
Transmission & Drivetrain
Feb 15, 2010 10:32 AM
accordredliner
Dec 31, 2005 09:28 AM
