Anyone with AEM PULLEY MOD ?
My problem "burning up alternators"
How does the Mitsubishi alternator mod work?
Is the mod made to solve my problem?
Is the wiring easy? what alternator works?
94 b7 block z6 head auto trans aceel cap and rotor with coil
also any good stand alone fuel management?
thanks
thanks
the the under drive pulley or.... AEM pulley mod
what it does is it turns the alternator, power steering and ac slower which frees up maybe a couple of horse power. but by doing this the alternator is working very hard because it is not turning as fast as the honda engineers designed it to work. so short story get rid of the pulley go back to stock replace the alternator and be done with it. you have a automatic mini me it's going to be slow no matter what you do to it.
a 5 speed tranny will make you faster then any bolt ons, or "mods" you can think of.
I know what it is. The OP is not clear on if he has it or is going to get it. And what is the Mitsubishi alternator mod? I haven't found any info on it. Mind you I'm not looking all that hard.
Best bit of advice is to put the stock pulley back on. You have a Civic. It's slow.
Draggin99Si
Aug 26, 2004 11:50 PM
