Suspension & Brakes Theory, alignment, spring rates....
axles dust rings? something is stopping ball joint from comming out.
Old May 31, 2011 | 11:05 AM
SQ is the SQUAD's Avatar
Default axles dust rings? something is stopping ball joint from comming out.
i was trying to change the ball joints on my 95 Honda odyssey knuckles. as i started to tap the ball joint out, i noticed it stopped and was hitting the back of the wheel bearing. i went back and looked at my 94 accord spindles and noticed the bearing sits a little more inward. someone mentioned that the odyssey may have an axles dust ring. i tired removing it, but it dident move. i dident want to destroy the wheel bearing.
Old May 31, 2011 | 11:41 AM
kyden's Avatar
Default Re: axles dust rings? something is stopping ball joint from comming out.
remove the wheel bearing? those 4 bolts hold it on.
Old May 31, 2011 | 12:06 PM
i tied that, it needed to be pressed out, i couldet get it to be tapped out. ci am going to order new bearings, but for right now, i cant damage these ones.
when i get home today i am going to try to remove the hub again so that i can hit the whole wheel with a wire brush and some paint so it can hold off til i hook my sand blast cabinet back up and powder coat it.
PreludeJunkie91
Jul 7, 2018 02:13 PM
alex1320
Mar 6, 2013 08:47 AM
dartonh22
Apr 2, 2012 11:55 AM
SQ is the SQUAD
Jun 2, 2011 01:56 PM
Phatwhippin_CRX
May 9, 2002 08:11 PM
