What is the difference in a GSR and LS cat-back?
Old Sep 30, 2002 | 05:17 PM
ITR1071's Avatar
Default What is the difference in a GSR and LS cat-back?
I have an LS, but I am about to buy an exhaust. I am also going to be swapping out my motor for a GSR so I want to make sure the exhaust will still work. I think it is the same up until the cat and then the GSR and LS headers are different. So would I need to buy a GSR cat when I do my swap?
Old Sep 30, 2002 | 05:23 PM
Cow's Avatar
Cow
Default Re: What is the difference in a GSR and LS cat-back? (undercoverSI)
The LS has a longer exhaust manifold (A pipe actually) than the 94-99 GSR. The 00-01 GSR's manifold is the same length. The cats on both models for all years are the same length.
If you get a 00+ GSR motor, it should bolt up. Otherwise you could buy an aftermarket header for an LS, and it will even out. Or just wait and buy a GSR exhaust.
Although you would probably be better off just turboing your LS motor, unless you are planning on going NA. For the cost of a GSR motor you could have a nice turbo setup.
HTH
(edited for clarity )
[Modified by Cow, 9:23 PM 9/30/2002]
styles671
Dec 31, 2010 07:09 AM
Jay Blazed
Aug 26, 2006 01:05 PM
kinvid22
Jun 8, 2004 11:41 PM
avividmemory
Feb 23, 2003 04:05 PM
vtecdc2
Sep 2, 2002 07:43 PM
