98 Prelude Factory Alarm Location?
I have a 98 Prelude with a Factory Alarm PN 08E51-SV4-102F connected to the car. I want to disable it because I have a Viper 5901 now but every time I unlock or do anything else with the Viper the Factory Alarm kicks in thinking the cars being broken into. Also if anyone has a wiring diagram for it it would really help.
http://www.collegehillshonda.com/ins...v/security.pdf
this is for a crv, but might help. You should be able to press unlock with the stock key-pad which is disarm and that should do it, unless your lock/unlock button on the door re-arms it, then you will need to put in valet. If you just unplug it or cut it out you may end up interrupting your starter wire.
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Can I get a picture of your remote? I never seen a 98 lude with a factory alarm. It might be a piggy back alarm tied into your keyless entry. It arms with the signal it gets from the car locking and disarms from the unlock signal. There should be a brain that says karr on it in the driver kick pannel.
B_Swapped93
Mar 19, 2015 07:31 AM
AznRacin621
Jan 4, 2008 02:39 PM
