Rear LCA bushing.
Old May 30, 2011 | 03:54 AM
bizak's Avatar
Default Rear LCA bushing.
I have been reading that you have to press the Rear Lower Control Arm bushing in/out. Is there anyone in here that did it himself without a press?
Old May 30, 2011 | 04:15 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Rear LCA bushing.
You will need a bench press to do that. Energy Suspension has that bushing if you need it. If not, just get yourself an aftermarket LCA and call it a day. I'm assuming there is a broken/rusted bolt where the rear shocks bolt up to?
Old May 30, 2011 | 05:38 AM
94EG8's Avatar
Seagull Management
Yes, good 4 or 5 inch bench vise and some huge washers and/or spacers and a large socket will work fine. I've done lots of them without a press.
Old May 30, 2011 | 05:47 AM
bizak's Avatar
actually the strut bushing is very bad, the bolts are fine. The only option i had is to take it to Honda dealer to do it since I bought the bushing from them cause noone else will install costumer parts. Is there a press that you can rent from advanceautoparts that I can use without removing the control arm?
Old May 30, 2011 | 07:33 AM
blaze_125's Avatar
easy task.
Take a hack saw and cut 2 slits through the bushing and the metal ring. Keep cutting until you get to the lca material.
Once your 2 slits are done, put a socket on top of the bushing and hammer it out.
Graybeard327
Honda CR-V & Element
Jul 16, 2017 06:42 AM
kasperxtcy
Suspension & Brakes
Mar 24, 2010 09:14 AM
Civic1992DX
Mar 23, 2003 06:10 PM
Kolijian
Jan 13, 2003 10:37 AM
Wes d
Jan 2, 2002 11:11 AM
