1990 Honda Civic Si hatchback *PART OUT*
Old May 29, 2011 | 05:10 PM
socialistic's Avatar
Default 1990 Honda Civic Si hatchback *PART OUT*
Parting out my '90 Civic Si hatch.
PLEASE READ FIRST BEFORE POSTING/PM'ING!
***Front calipers, front brake lines, front rotors, front knuckle assembles, front struts, front springs, front upper control arms, outer tie rods, master cylinder, rear struts, rear springs, motor/trans, ecu, axles WERE ALL SWAPPED with '90 DX parts because that's the car I'm building. If you ask for any of those parts, I will remind you of this. The interior was also gutted, but I may still have some of the black spraypainted plastics, just ask. The d15b2 dpfi drivetrain out of the DX is for sale, local pickup only, motor bogs under throttle and consumes oil, no engine harness, trans had no issues in the 20 or so miles it was driven by me after purchasing the car.***
PM me with a list of what you want, I'll reply with what I have, you reply with an offer. Low-ballers will be laughed at. I accept paypal(verified user) only!
I will add all the sold parts and parts I don't have to this post periodically, so you don't end up asking for parts I don't have anymore. I can generally get stuff shipped out Monday and Tuesday, busy the rest of the week so don't throw a fit if you pay for something Wednesday and it doesn't ship until Monday.
Parts I don't have/sold-
-Front driver headlight
-Radio harness
-Pedal assembly
-Shift linkage
-Rear trans mount(both halves)
-Corner signals
-Clutch cable
-All six front signal sockets + wiring
Old May 30, 2011 | 12:34 PM
Default Re: 1990 Honda Civic Si hatchback *PART OUT*
ttt
Old Jun 10, 2011 | 11:02 PM
ttt
Considering how hard it's getting to find EF parts, I'm surprised I've yet to receive a single reply or PM. o.O
So many nice parts just waiting to be snatched up!
Old Jun 11, 2011 | 01:44 PM
fredefhatch's Avatar
you said ur interior was gutted but by any chance do you have the seat rails?
Old Jun 11, 2011 | 01:45 PM
Nope, no seat rails. The car originally came with DA seats that were only held in by two bolts each due to the DA rails not matching up with the EF floor bolt holes.
Old Jun 13, 2011 | 10:45 AM
Do you have the exhaust cat-back?
Old Jun 13, 2011 | 10:48 AM
Yes, and it didn't leak or anything when the car was running. I also believe the muffler assembly was replaced at some point, it's OEM style but I didn't check where it connects to see if they clamped/welded/bolt-flanged it.
Old Jun 13, 2011 | 03:41 PM
dc5itracer's Avatar
I need radio harness if you have it and I need the sockets for side markers and bumper lights
Old Jun 13, 2011 | 03:45 PM
I have all the sockets for the front corner signals and bumper lights, but the front passenger corner sockets and wiring were replaced by me at one point because the old stuff was all hacked. It all works and looks fine, but the wire colors for those two sockets I don't think matched up with the existing wiring...wouldn't be hard to figure out, though.
The radio harness was cut because my other civic needed the plug + some length of the wiring.
Shoot me an offer(shipped) for the 6 light socks+pigtails via PM.
Edit: Just noticed you said side-markers...so you do mean side-markers as in the JDM side-markers, or corner signals? This car is USDM and therefore does not have side-markers.
Old Jun 14, 2011 | 11:16 PM
longhairbro17's Avatar
What condition is the transmission in. I need to do full auto to manual swap. Also what condition is tge hood in?
Old Jun 14, 2011 | 11:46 PM
As far as I know, there's nothing wrong with the transmission but I only drove the car about 20 miles after buying it. It didn't grind in any gears, clutch felt fine but needed a cable adjustment which I didn't bother with since I was planning to do the MPFI/SI conversion to that car anyways. It's still attached to the DPFI motor, so I haven't even seen the shaft/spring/throwout bearing to know if they're in decent shape.
The hood was fairly clean from what I can remember, the spring was a little soft so it didn't pop sometimes which is an easy fix. I *think* I remember seeing a small dent somewhere on the nose area of the hood that broke the paint seal and had a little surface rust.
The trans will be a bit pricey to ship, last I shipped one was to Washington state and it was somewhere between $50-75 and that was like 5 years ago so it will probably cost substantially more these days. The hood will be more expensive to ship due to it being classified as "oversized", and will surely get beat up in transit.
Old Jun 15, 2011 | 08:41 AM
ryguy2588's Avatar
How much for the tail lights?
Old Jun 15, 2011 | 09:02 AM
censurebush's Avatar
From: everything for everyone, and nothing for ourselves
manual pedal assembly and brake booster
Old Jun 15, 2011 | 01:41 PM
PM inbound
PM inbound.
Old Jun 28, 2011 | 05:18 AM
Bumpity bump!
Old Jun 28, 2011 | 05:45 PM
civic'x's Avatar
do u have the cluster cover with switches.....lmk and what color?
Old Jun 29, 2011 | 07:05 AM
Yes, and everything has a nice coat of black spraypaint over it...including the switches. The last owner annihilated the interior with several coats of spraypaint ranging from white, to red, to lime green, to black.
Old Jun 29, 2011 | 05:26 PM
Acharity29's Avatar
do u have the headlight harness & fan relay (cables,wires)
Old Jun 29, 2011 | 05:27 PM
Headlight wiring is still there, not sure about the fan relay mainly because I don't know what it looks like or where it would be.
Old Jun 30, 2011 | 02:50 PM
Bump it up.
Would be interested in trading for a VTEC head that will fit my d16a6 block!
Old Jul 1, 2011 | 06:53 AM
Ttt
Old Jul 3, 2011 | 09:40 AM
Bump!
Old Jul 4, 2011 | 07:06 PM
Redline4Life's Avatar
do u still have the headlights????
Old Jul 4, 2011 | 07:41 PM
Only the passenger light, and it has some rust inside of it. Driver light has a hole in it.
Old Jul 31, 2011 | 07:43 AM
Bump!
This may be my last bump, I haven't been getting many part requests/offers and this car is taking up valuable garage space so I may take a few things from it / load it up with scrap and send it to the scrapper. So if you need any parts, hit me up fast!
I AM INTERESTED IN TRADES! The only stuff I am looking for at this time are:
-Intake for a 90-91 Civic Si(OEM or Aftermarket)
-Battery tie-down for the same car(OEM or Aftermarket)
-Complete VTEC head(either for a d16a6 block or d15b2 block, not sure if it matters)
