Who wants to earn a $grand, help!
98 ss prelude needs to have the 5spd conversion.
I live in ventura Ca. and my car does not want to travel too far and I recently herniated two discs, so I can't do much work by myself.
I have tried asking around on socalprelude.com and no one is interested in taking the job. I can help some but no major lifting, I can offer about a grand to do the job right, which definitely includes reinforcing the firewall for the clutch pedal, steel plate.
I may be able to pay for one or two tanks of fuel to get here and buy lunch. I need it completed within a couple weeks if possible
Thank you for helping and feel free to ad any thoughts, ideas or advice. Also I have the ecu covered most likely, and no shops around here will take it on.
I hope someone can help.
-tex
-tex
A shop, your right, no way.
A ny and all advice, thoughts and help are welcomed.
ThanksFor your reply (not sarcasm)
if you had the parts... i would do it.. however.... you are nowhere near me..
considering that i have most of the parts that you will need..
better yet pm me with parts that you may still need. if your interested
Ok it would not load the private message screen, so here's what I need.
-97-01 prelude manual trans:
can you list all the parts that it comes with?
The miles?
Condition, any grinding or slipping gears? (need to know before its installed so I can fix)?
How did you end up with this tranny?
Limited slip?
-Manual transmission mount:
-manual flywheel:
-clutch kit:
Clutch, pressure plate, throughout bearing, pilot bearing
-flywheel & pressure plate bolts
-hydraulic clutch lines
-clutch pedal assembly
-manual brake assembly
-manual shifter assembly
-short shifter
- shift cables and linkage
-manual intermediate shaft (half shaft)
-clutch master cylinder
C anyou please comment or list rather, everything you have and as many, details as possible, pricey as well please.
A s much detail as you can write for what you have please, pricing for each item.
T hanksagain!
,H aha wanna visit ventura or santabarbara?
The miles?
Limited slip?
-manual flywheel:
-clutch kit:
-short shifter
T hanksagain!
migs
21
Sep 9, 2002 02:48 PM
