95 civic with zc motor need help
Old May 29, 2011 | 09:14 AM
cashmoney811's Avatar
Default 95 civic with zc motor need help
ok i have a 95 civic with a zc motor in it and yes on the block plate it only has zc but the head numbers come back to a d15. so my question is did somebody but that head on or is there a zc motor that comes with a d15 head on it. it is a sohc non vtec. ive been searching forums about zc motors and all i get is mixed info on them. any good info on this motor would be good.
Old May 29, 2011 | 06:41 PM
AmorshC's Avatar
Default Re: 95 civic with zc motor need help
http://en.wikipedia.org/wiki/Honda_D_engine
ZC Motors info
The ZC motors are the import motors, usually from japan. They're similar to your d15/d16 motors in your US cars.
Old May 29, 2011 | 07:16 PM
ya i looked there similar to d16 but my head code is pm3-8 (9/3) which i keep getting told is a d15 head. im just try in to find out if the head is a zc head or if sombody but that head on a zc block for some reason.
Old May 29, 2011 | 10:11 PM
pmar91's Avatar
I have a ZC block also with a D15 head. Mine isn't vtec tho. You can tell if it's vtec if you have a solenoid or if your plugs on your head are on the bottom instead of the top.(I think)
Old May 29, 2011 | 10:29 PM
so thay say a zc is like a d15 and d16 so if the head comes up d15 does that mean the bottom end is more like a d15 than a d16
krysted9354
May 17, 2009 09:47 PM
sean burke
Apr 3, 2009 09:27 PM
91ZCcivicSi
Feb 5, 2005 07:12 PM
CRX_RUS2
Nov 26, 2004 12:52 AM
