Transmission & Drivetrain Gearboxes, Differentials, Clutches
How to tell if this tranny is LSD?
Old May 29, 2011 | 08:40 AM
Slacker93eg's Avatar
10 Year Member
Default How to tell if this tranny is LSD?
I found a gsr hydro trans on craigslist for 250, I got him down to 200. He has no idea how many miles are on it or anything, doesn't even know if its LSD. He bought it and never used it he says. It's just the gears and trans case, nothing else.
First, is this a good deal?
Second, how do I know if its LSD
Thanks in advance.
Old May 29, 2011 | 08:51 AM
SpokaneSpeed's Avatar
Default Re: How to tell if this tranny is LSD?
Its a GREAT deal IF the tranny is actually good... which i highly doubt it is, for that price.
You'll never know if it has an aftermarket LSD unless you actually take it apart. No USDM GSR tranny came with a factory LSD. Some JDM GSR's did however... should have a stamp on the casting... something like Y-LSD, or just LSD.
Someone correct me if im wrong...
Old May 29, 2011 | 09:17 AM
10 Year Member
Thanks for the reply dude, I think I may pick it up either way though. I just bought a b18b for 200$ too lol, engine head intake mani and exhaust mani. Not a bad deal I dont think. I need a trans, and I'm having a hard time finding ANY b series trans around here.
I'll have to find out if there's a visible stamp on it
Old May 29, 2011 | 09:48 AM
Yeah B-series trannys have become harder and harder to come by... and more and more expensive. Good luck
Old May 29, 2011 | 11:41 AM
10 Year Member
Thanks dude
Old May 30, 2011 | 05:04 AM
94EG8's Avatar
Seagull Management
Look through the diff where the axles go in, if you can see straight through it's a got an LSD, if you see a bar it's an open diff.
Old Apr 16, 2015 | 07:58 AM
K/b-em1john's Avatar
Some Usdm gsr tranny and usdm so trannys have lsd diff , everyone that I have owned has anyways it'll be a s or y80 and yes if it's if its hollow it's lsd if there is a bar it's open like the other fella said , also the gsr lsd is the best diff it's stronger than the si/siR diff , also the b16b type R tranny came with a helical lsd out of all the lsds the b16b type R is the best , as for gears that depends on what motor your running
Old Apr 16, 2015 | 07:58 PM
Wow.. bringing back a dead thread from 4yrs ago bud?? lol...
Old Apr 16, 2015 | 08:19 PM
Tegra206's Avatar
Aw sh*t! Now you gone and done it!!!!
Old Apr 16, 2015 | 09:57 PM
philcivicjordan's Avatar
If she has a lump in her pants and it's seeing dragons then you probably got yourself a tranny on lsd
Old Apr 16, 2015 | 10:24 PM
Lol!
Old Apr 16, 2015 | 10:49 PM
Tegra206's Avatar
HAHAHA!!!!!
Old Apr 10, 2017 | 11:03 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It's not a LSD transmission just because it leaves two black marks... you are driving perfectly straight. Turn the steering wheel 90' and try it again and see how many black marks you make then. The sure way to know if to pop the passenger side axle out and see if there is a 1/2" diameter bar running across the middle of the opening... if you see it, NO LSD. If it is open and you can see the center of the end of the mid-shaft... it IS an LSD transmission.
highmilehatch
Jul 18, 2007 06:35 AM
tvrsir
Jul 28, 2004 04:17 AM
CR-V-tech
Oct 29, 2003 05:37 AM
chirp2hrd
13
Jan 10, 2003 02:14 AM
