cant bleed rr and lf gsr calipers
to make a long story short i have a 94 gsr stock brakes rears where pinching too hard on the lr and not touching on the rr i tried new pads the calipers went back in tough but went in and thats how i noticed they wher wearing weird so i replaced the rear calipers and cant bleed the rr and lf he pumps slowly i crack it and it drips out slower than a gravity bleed. i went around the car two large bottles of brake fluide it must be he prop valve or the metering valve? please help gotta fix this before tuesday so i can get to work thanks
If it doesn't bleed, pull the bleed screw out and run a drill bit down it and then through the side if you can still see that part. or replace it.
Be patient, someone will help you eventually. If you ramble in a hurry most people are not going to reply, especially if you are not going to take the time and post as much detail about your problem as possible, your not texting on a phone here.
