Gsr block , questions on internals!
Old May 28, 2011 | 07:33 PM
brooklynEG's Avatar
Post Gsr block , questions on internals!
Hey ht I have a build in process , I have a gsr block at the machine shop that I just purchased
The story behind the block is the piston in cyclinder 4 chipped off , when I got the block I took the crankshaft , pistons out and the oil squiters in cyclinders 1,4 were broke off into the oil pan... Took the flywheel to get resurfaced , crankshaft to get polished , and block to get looked over and cleaned
The results of the block were that cyclinder 4 is fine but 2,3 are warped. I thought 1,4 would have the damage but ohwell, also the block needs to be decked.
So my plans are to bore out to 82.00 , with rsmachine itr pistons so heres where my questions come in
.Should I take the old pistons off the rods, and put the itr pistons on the gsr rods?
.Or should I just get forged rods? (ive searched but havent found much info on forged pistons on cast rods )
.since im going to do a bore do I still need the oil squirters?
The plan for this build is a Allmotor gsr with power hopes of 200+, BUT This is my first build , im trying to do it right tho so its not timed, I just need this help so I could move forward
ty521825
Jun 15, 2011 01:11 AM
brooklynEG
May 31, 2011 08:17 PM
cluelessmale
May 28, 2007 07:43 PM
jdm'dc2sc61
Apr 9, 2005 02:13 PM
Alpha_GSR
Dec 28, 2002 09:56 AM
