84mm with stock GSR rods
Old Sep 30, 2002 | 03:59 PM
blazin's Avatar
Default 84mm with stock GSR rods
Is it safe to run 84mm Endyn pistons in a N/A settup with stock rods?
Old Sep 30, 2002 | 06:16 PM
dohcsideSi's Avatar
Default Re: 84mm with stock GSR rods (blazin)
you can't run a endyn piston on a stock rod.....they use a floating pin.
Old Sep 30, 2002 | 06:19 PM
MackSpeed-616's Avatar
Default Re: 84mm with stock GSR rods (dohcsideSi)
since when?
Old Sep 30, 2002 | 06:20 PM
blazin's Avatar
Do any forged piston manufacturers have pistons/pins that will work with the stock rods?
Old Sep 30, 2002 | 06:22 PM
dude.. you can use a stock rod with a floating pin piston.
Old Oct 10, 2002 | 05:54 AM
blazin's Avatar
Default Re: 84mm with stock GSR rods (BustaNutt-616)
Anybody see using forged pistons with the stock rods in a N/A settup making around 225whp a problem???
Old Oct 10, 2002 | 11:09 AM
slofu's Avatar
you can have the small ends of the stock b18c rods bushed (opened) to use a fully-floating wrist-pin, or you may just be able to have the pins pressed into the rods so they only 'float' in the pistons (like stock, though i'd not advise it- i don't know if you'd use a stock pin or those supplied by Endyn), but by the time you pay for the machine work (press in pins, or bush pin-holes), and get ARP rod-bolts (which you should if you plan to hit 200+ whp or rev past 8400rpm), it'd be foolish not to buy Eagles for ~$350, which include ARP bolts, will accomodate a fully-floating pin. if you insist upon stock rods, if they are not new, you may want to have them shot-peened again (as Honda does at the factory) to increase tensile strength, though this is yet more $ for a service unnecessary if you get the Eagles (or Crowers, Cunninghams, etc., but these are $$). Still, stock rods will never be as strong/reliable as Eagles, etc., and pushing ~225whp, your tuning will be critical (as with any setup); advance ignition too far or run too lean and detonate, and the stock rods will not be as forgiving. i've seen a few bend (even break) even in NA setups with less power.
Old Oct 10, 2002 | 11:32 AM
sgT's Avatar
sgT
Default Re: 84mm with stock GSR rods (slofu)
I've been making 200-220whp on various motors with stock rods for years now.
vtec(ie b18c1/5) rod bolts are plenty strong.
While it is true that stock wont ever be as strong as eagle, they dont have to be.
I'd like to know what causes a rod to spontaneously bend......
Old Oct 10, 2002 | 12:12 PM
dohcsideSi's Avatar
with STOCK rods?
stock rods no....modded stock rods why??? get a set of eagles for $350
Old Oct 10, 2002 | 12:24 PM
JPP's Avatar
JPP
Default Re: 84mm with stock GSR rods (sgT)
What is important to understand is not how to bend the rod but that there is no rod...sorry just had a Matrix flashback... long day at work...
Old Oct 10, 2002 | 01:33 PM
slofu's Avatar
stockers will not spontaneously bend; they bend easier than stronger rods (Eagles, etc.) under detonation from poor tuning; running too lean or with ignition advanced too far.
Ericbalanzar
Feb 11, 2015 05:14 PM
Project_SOHC_EX
Dec 19, 2009 11:58 AM
lilpastrana
Apr 17, 2007 03:45 PM
RACING INTEGRATION
Jun 2, 2005 12:22 PM
