will legend caliper swap mess with my abs unit on db7
im planning on doing a legend caliper upgrade on my db7, but i was wondering if it will mess up my stock abs unit in any way?. my car is completely stock just doing it for the bling cuz im planning on polishing them up.also for a everyday driver is it overkill?
Last edited by jdm mafia; May 28, 2011 at 09:12 PM. Reason: for got to add another question
I first put NSX calipers in front, similar to Legend, and left the back stock, then later used RSX calipers in back. ABS worked fine all along. That is on a 95 and I believe the ABS is slightly different, but yours should work. There are many threads on NSX and legend conversions, and I do not remember any ABS issues. You could search the conversions.
i searched and read several threads about them, most people dont have abs when they do the conversion, i did find some body that said his tires kind of locked up on him, thats what im scared off, i dont want to be on the freeway and the tires locking up on me.where u stock motor? was it overkill for u for everyday driving?
It is overkill for every day. You started with wanting bling. I use NSX front and RSX rear on the track, with track pads, to help with heat fade. I use ABS and it works fine. I also drive it on the street with street pads. I do not think it is worth the hassle or money for everyday, but for bling, up to you.
dam, i was hoping it wouldnt be that bad with them. maybe i should just polish the ones that i have on now. but i just thought it would look really good with a big caliper all polished up. is it that bad? im wondering if its that hard of a stop.
The brakes on your car were designed for the everyday driver from the factory, now if your not an "everyday" kind of driver that is another thing altogether.
Cyber ITR
Dec 27, 2007 09:03 AM
2wheelhunter
May 6, 2007 07:33 PM
slammed_93_hatch
16
May 12, 2005 12:19 PM
