no power to starter
Old May 28, 2011 | 10:20 AM
topp_dawg_g's Avatar
From: springdale, arkansas, United States of America
Default no power to starter
just dropped a d15 in a 88 crx. while tightening the positive on the battery i hit ground with my rachet. for some reason, the key was in with the ignition on. now the starter won't run when cranking. it still work if i hook up power to the starter signal. i also can't hear the fuel pump when turning onto ignition. i think it could be the ignition switch or main relay but i had never dealt with those parts before. any one got suggestions? thanks
Old May 31, 2011 | 01:49 AM
benny_ng's Avatar
Default Re: no power to starter
get a multi meter.
test to see if the battery is even still good, depending on how long the ratchet was there, the battery may be bad, check the main fuses.
had a similar problem on our 89 crx, (w/o doing the ratchet thing). and we would yank on the wire to the starter, and things fixed itself. it wound up being a loose wire. so check all the wires going to/from the battery, incl the grounds.
J1MMY420
May 16, 2014 08:46 PM
miked123
Jun 27, 2013 04:44 AM
jbs
Oct 3, 2006 10:26 AM
rex_racer728
24
Feb 3, 2006 10:57 AM
Nisif
Nov 3, 2005 08:34 PM
