Phearable chips for JDM F20B DOHC Motor
I have running the P28 chipped ECU on a JDM Accord CF4 Sirt (OBD2B) and I have bought the basemap chips from phearable.net recently. When I try the new chips on yesterday, the CEL was ON during startup.... will it be the problem due to VTEC pressure switch not exist on the JDM Motor?
I know there is a ways to bypass using the trick "skywire" (A4 to D6).....but I dunno which location I can do such .....as I'm using the OBD2B-OBD1 conversion hardness.....
can anyone give me some hints?
I have fixed the issue on the CEL#22 on by adding the skyline between A4 and D6...
However, when VTEC kick-in....seems that the VTEC is ON and OFF for between the 5000-5300 rpm......any hints on that? no CEL was throw this time....
Check your oil levels. If you are throwing no codes & vtec is intermittently working, the issue is usually mechanical
Kirk@SyndromeAuto
Jan 14, 2007 10:20 AM
LShatchie
19
Oct 3, 2006 07:04 PM
