Precision turbo kit D-series complete! $1600 SHIPPED
Old May 27, 2011 | 09:50 PM
jhojhet's Avatar
Default Precision turbo kit D-series complete! $1600 SHIPPED
THIS IS A KIT THAT I HAD IN MY 97 CIVIC AROUND 3000 MILES AND DECIDED TO SELL THEM NOW SINCE I'M STARTING A TOTALLY DIFFERENT PROJECT.
ALL LISTED BELOW ARE ALL INCLUDED PLUS YOU WILL GET A TUNED EPROM THAT CAN BE installed TO ANY P28 ECU AND YOU ARE SET TO GO
THE SOFTWARE THAT WAS USED TO TUNED MY CAR WAS ECTUNE, THIS IS PROGRAMMED TO THE EPROM THAT YOU WILL BE GETTING. (WITH THIS EPROM YOU CAN RAN WITHOUT ISSUES BETWEEN 10 TO 24 LBS OF BOOST SAFE).
WITH THAT IN MIND, YOU DONT NEED TO GO TO THE SHOP TO TUNE IT!!! ANS SAVE YOU TIME AND A LOT OF MONEY APPX $500.00 ON TUNING.
YOU WILL GET :
ALL PIPING FROM TURBO TO YOUR THROTTLE BODY
ALL COUPLERS NEEDED
ALL T-BOLT CLAMPS NEEDED
HKS SSQ BOV INSTALLED ON ONE OF THE PIPE
PRECISION INTERCOOLER AS SHOWS IN THE PICTURE RATED 450HP+ (COMES WITH BRACKET)
INJECTOR DYNAMICS 725CC
SAMCO HOSE FOR THE INTAKE PIPE
REV HARD TURBO MANIFOLD (VERY GOOD CONDITION NO CRACKS)
PRECISION TURBO 50 TRIM ( NO SHAFT PLAY AT ALL SPOOL FAST!)
2.5 TO 3" FROM TURBO TO DOWNPIPE ADAPTOR (V-BAND)
3" DOWNPIPE WITH V-BAND + V-BAND CLAMP
3" CAT ( YOU WILL NEED TO REMOVE YOUR CAT AND BOLT THIS ONE ON TO YOUR CAT BACK EXHAUST SYSTEM)
1 SANDWICH OIL ADAPTER THAT WILL BE INSTALLED TO YOUR OIL FILTER
1 LINE FROM YOUR SANDWICH ADAPTER TO THE TURBO ( ALL LITTLE PARTS ARE INCLUDED SO IT WILL GO SMOOTHLY)
1 3BAR MAP SENSOR
I WILL ALSO THROW A MINT CONDITION HALLMAN BOOST CONTROLLER
I WILL ALSO ADD AN EXTRA OIL RETURN LINE HOSE FROM TURBO TO YOUR OIL PAN + 2 CLAMPS
THE CAT CONVERTER IS NOT IN THE PICTURE BUT IT WILL BE INCLUDED.
THE OIL PAN IS NOT INCLUDED IN THE PICTURE AS WELL AS THE TIAL WASTEGATE.
WHAT YOU'LL NEED:
P28 ECU
WASTEGATE
INJECTORS ADAPTOR TO YOUR LINE ( YOU CAN CALL INJECTOR DYNAMICS FOR $30.00 +/-
http://i1182.photobucket.com/albums/...t/DSC_0025.jpg
http://i1182.photobucket.com/albums/...t/DSC_0024.jpg
jhojhet
May 30, 2011 08:35 PM
Louis53123
Northeast (Sales)
Mar 29, 2006 06:07 AM
Louis53123
