FS: ScanGauge 2
I have the Scan Gauge 2 up for sale, this is a cool little thing to have in your car regardless of whether its modified or what...its cool to watch what the vehicle is doing without having to run any kind of wiring whatsoever. This simply plugs into the vehicle's diagnostic port!
$130 + shipping. E-mail will get you the fastest response - hondafrk2004@yahoo.com.
Displays:
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Intake Air Temperature
Engine Speed (RPM)
Vehicle speed (MPH and KM/H)
Manifold Pressure(not available on some vehicles)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
*Compact size
*Fits almost anywhere!
*Works On 1996 & Newer Vehicles Including: Gas, Diesel, Propane and Hybrid Vehicles
*Detachable Cable
*Allows for easy portability from vehicle
to vehicle.
*Menu Driven Operations
*Works On All OBDII Protocols Including CAN, required on all vehicles starting in 2008.
*Large High Contrast LCD
*User changeable backlight color
There's also a suction cup mount available on Egay, I may get one soon if this doesn't sell.
Displays:
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Engine Speed (RPM)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
*Compact size
*Detachable Cable
to vehicle.
JackSparrow
Honda Civic (2006 - 2015)
23
Feb 17, 2017 05:23 PM
