High Flow Cat and/or Test Pipe Questions...
Old May 27, 2011 | 05:44 PM
PreClude's Avatar
Default High Flow Cat and/or Test Pipe Questions...
First, where are some reputable places to purchase one?
Second, what fits? My stock cat (I'm assuming) has three bolt flanges on both sides. Some of the ones I'm looking to buy online have 3 bolt holes on one side and only 2 on the other.
Old May 27, 2011 | 06:07 PM
serrilion's Avatar
Default Re: High Flow Cat and/or Test Pipe Questions...
The cat depends on your exhuast that you plan on bolting up to it. I've seen cheap hi fow cat's on ebay for like $10 bucks that flow just as well as a test pipe you can custom weld... I'd say ebay if your looking for a cat delete ... just me tho
Old May 27, 2011 | 06:54 PM
PreClude's Avatar
Thanks. I'm looking For something that will bolt right up to what I have now, that's why I was asking about the 3 and 2 bolt flanges. I don't kno what is and what is not stock.
Let's say you don't have or want to use eBay....any other places to look? Brands? Companies? Websites for Prelude stuff?
Old May 27, 2011 | 09:56 PM
P. Hunter's Avatar
personally i have a Megan racing 2.5" exhaust header back.. i had a high flow cat welded in where the test pipe would be.. sounds great and runs great.. it also passes emissions which is a double plus
Old May 27, 2011 | 09:58 PM
P. Hunter's Avatar
life will be much easier if you just pay out the money to have a universal cat welded in..
Old May 27, 2011 | 11:00 PM
PreClude's Avatar
I thought the idea behind flanged exhausts was for making life easier lol... you know, so you can essentially change out your exhaust by yourself in a parking lot vs having to take it to a shop and have them weld it in.
Plus, what happens when it goes bad? You have to get it again re-welded. I had this problem on my Jeep where they do not make exhaust setups that are pieced together with flanges, and that's what I was trying ti get away from. On my WRX, you don't have to weld anything on. Everything bolts up perfectly. Why spend the extra $ for the welding? ESPECIALLY if you go with a test-pipe which NO ONE is going to weld on for you, you know?
So if I had a test pipe that I could just bolt straight up to what I already have existing in place....
Trackin'?
Old May 28, 2011 | 05:47 AM
P. Hunter's Avatar
well that depends.. you can get a cat that fits the stock pipe but if you have pipes that are bigger its obvious that a stock cat with stock flanges are not going to fit..
i know people do make high flow cats for stock exhaust pipes.. i seen many while i was searching to find one that would fit my non-stock pipes
Old May 28, 2011 | 05:50 AM
P. Hunter's Avatar
just an example.. is this that you are looking for??
http://www.proimporttuners.com/parts...mpaign=product
Old May 28, 2011 | 06:16 PM
PreClude's Avatar
I guess I need to get a tape and see exactly what size my piping is now. The PO hackjobbed a lot of stuff on my car so I am not entirely sure what is stock and what isn't. That's why I was asking about the flanges especially. I wasn't sure if our cars came stock with a 3 and 2 bolt flange cat or not.
Thanks for that link Hunter. That's along the ideas of what I was thinking about yes. I might get that. If I can save $60 in the process though and get something like this, I would:
Just not sure if that will bolt up or not. As for throwing any CELs, the idea is that once I get my P72 ECU running correctly on my car, hopefully that will take care of the rear O2 sensor...
Old May 29, 2011 | 08:38 AM
P. Hunter's Avatar
i have a full megan racing header back.. the pipe is 2.5" and im pretty sure that one will be the same way and it wont right.. im not completely positive but im pretty sure it wont fit right
Old May 29, 2011 | 12:48 PM
PreClude's Avatar
So it looks like I'm just going to have to shell out the money for a local shop to weld a universal cat on I guess.
Old May 29, 2011 | 02:24 PM
P. Hunter's Avatar
flow master makes direct fits..
Old May 29, 2011 | 05:09 PM
serrilion's Avatar
The cat pictured above looks like a HI flow cat that a eg civic would use to bolt up to its header and exhuast... I know u can go on ebay and find what u are looking for , for like 30 bucks... they are safe, done well and just a simple bolt up with gaskets lol
Old May 29, 2011 | 10:56 PM
PreClude's Avatar
Right on guys. I just don't know if our Preludes come stock with a two bolt flange on one end and 3 on the other? Or is it 3 on both sides? Because that's what I have on there now.
Old May 29, 2011 | 11:31 PM
P. Hunter's Avatar
my 5th gen had 3 bolts at each flange
Old May 30, 2011 | 04:43 PM
PreClude's Avatar
So stock they have 3 bolt flanges at each end, correct?
Same with aftermarket?
Maybe the pics I see online are just a little deceiving. I just don't want to spend $200-300 if I don't have to....as far as buying a $100-150 cat plus paying someone to weld it on. I would much rather buy a $50-100 hi-flow cat or test pipe with 3 bolt flanges on each end and install it myself.
Skatnshawn
Nov 11, 2012 07:06 AM
B serious
Jan 10, 2011 04:38 AM
recon23
Jan 8, 2008 10:37 AM
X2BOARD
11
Apr 8, 2005 03:16 PM
