p13 h22 head bluetop/direct port nitrous kit fs/ft! show me what you got!!!!
81k on the motor when the head was pulled. Removed the vc so you can see how clean it is on the inside. I have the complete head from the tb all the way to the headgasket I will supply with the trade or purchase. Has all the parts that complete to the head. Everything...nothing is missing. The head has been deck milled to make sure nothing was wrong with it. Its perfect. Only parts you need to supply is a dizzy and wires and a timing belt and you are ready to ride. $500
Direct port nitrous kit has dry and wet solenoid, the direct port bracket, bottle, bottle warmer, all hoses, all switches, wide open throttle switch, nitrous guage.
The parts in the picture are the only parts I have removed from the plastic. When the kit was purchased I spent $800 and I have the receipt.
Contact: 252-676-5221 never check pms.
Items Im looking to trade for are:
f23 intake manifold
guage pillar oil, a/f, boost, voltage, coolant temperature, egt
boost controller (nice one, not ebay garbage)
vtec controller (once again, nice one)
indash navigation unit
bisimoto or gude cam shaft stage1 or 2
polished or painted valve cover
1000watt class d amps (nice no bs)
12 inch subwoofers (quality over quantity)
Rims and tires
black turbo muffler
Just hit me up and lmk what you have. The worse I can say is no.
252-676-5221 or comment in this thread, pm me...thanks...
91tegrals
Texas -OK -LA (Sales)
Mar 25, 2008 08:23 PM
