ek coupe/ da teggy
whats up Honda Tech im going to install my radio and sound system which is a sub and a amp but dont know how to do it exactly heard its not hard to do, ive research online but havent found anything. Wanted to know if someone can help me out, i was planning on doing it to my da and if everything comes out well do it to my bros ek coupe. Also is there a difference in wiring with the ek and the da?
Thanks
Thanks
Easiest way: go to walmart and buy the scosche wiring adapter for the car you're putting the radio in. Follow the wiring instructions from the radio and the adapter harness and connect the wires all together. Unplug the factory radio (or whatever is there) and everything should clip together and fit right in. Don't forget to connect your RCA cables and remote power wire while you're in there. If you can get the radio installed, you should be able to do the amp. Let us know how it goes and we'll take it from there.
^^^^ just buy a wiring adapter splice ur radio harness into that and plug and play so if ever needed you can plug up stock radio best way to run wires for amp and sub i found in my Civic 97 Ej6 4 door is take out the center console run them udernet the carpet than in the back squeeze the back carpet where the center part is so u can get ur hand underneth and pull it underneth the back seat it makes it a very clean install whit no wires anywhere and for the power cable from the battery i ran it trough the firewall there is a rubber gorment u can put a notch into and run ur power trough there its in the passanger compartment where the heater core is and the rubber gorment is right below the battery i can take some pictures when its not dark if you need me to
cooljnateman
Feb 17, 2010 01:44 PM
