Swapping out F23a1 VTEC 4cyl.
Ey wuz up i wantin to rip out my f32a1 out my 99 accord coupe lx an dropa new engine in it pero idk wut engine i should drop in it for the most power an hav it actually compatible wit fittin in my car an havin evrythin line up wit least amount of fabrication work to the frame. If anyone could give me any suggestions id really appreciate it bcuz itz drivin me crazy haha thanx...
Please read through the forum FAQ or search the forums and you will find your answers.
Threads like this happen literally at least once a week so there is plenty of info floating around.
Boosting the F23a1 is also an attractive option, considering you can make more power than a stock H-series or J-series swap.
There is a complete H22 swap guide for 6th generation Accords in the FAQ and plenty of other threads about the same swap, as well as for the F20b and the J-series.
Make sure in this site's search engine to specify your search for just this sub-forum (Honda Accord 1990-2002) and you will get better results.
Good luck with whatever you decide.
Then you didn't look very hard at all...
However, if you search, there are plenty of threads discussing the swap. Here is the most in depth one I've seen at a quick glance:
https://honda-tech.com/forums/showth...h+gen+h22+swap
Again, if your questions aren't answered in that thread, try searching "6th gen h22 swap" in this sub-forum.
Good luck!
cody_sandlin
Oct 23, 2011 03:20 PM
