How much does a crx shell weigh
Old May 27, 2011 | 08:57 AM
nihad's Avatar
Default How much does a crx shell weigh
I have a 90 crx hf shell i just parted out and only thing left is the rear spindles and lca and front glass everything else is gone hole in the roof.. What do you guys think it weighs also the rear crash support is on it.. i was thinking 700LBS what do you guys think..
Old May 27, 2011 | 08:58 AM
kaiba's Avatar
Default Re: How much does a crx shell weigh
701
Old May 27, 2011 | 09:44 AM
nihad's Avatar
701 you sure..
Old May 28, 2011 | 12:40 PM
da_all_day's Avatar
i think hes messing with you....
Old May 28, 2011 | 06:02 PM
nihad's Avatar
does anyone know..
Old May 29, 2011 | 02:47 PM
burnykawizzle's Avatar
the best closes way to find out the weight is by going to your local gym, talk to a few body builders, have them come over and lift it up.. since they are body builders they will tell you a few pounds in the estimate of what it weighs.. if you are a shy person then i suggest for you to take it to a truck stop and throw that bish on the scale....
those are your only 2 options
Old May 29, 2011 | 02:56 PM
lazlong's Avatar
Considering I've seen them weigh in around 1000-1100 lbs completely stripped and still running 700 lbs isn't a bad guess.
Old May 30, 2011 | 07:53 AM
nihad's Avatar
completely stripped and no doors or hatch only rear spindles.. Id say around 700-800
Old May 30, 2011 | 12:52 PM
Eric W's Avatar
im in the process of stripping a 1990 si crx and Ill just scrap the bare shell after Im done. I could use this info aswell
Old May 30, 2011 | 02:45 PM
nihad's Avatar
I sold my shell for 50$ im sure it might of been worth a little more.. .07cent per LB take it to a steel scrap yard not junkyard..
Old May 30, 2011 | 04:08 PM
spoonfedcrx's Avatar
If you strip it down to a real shell two people can pick it up with ease.
Old May 30, 2011 | 04:44 PM
nihad's Avatar
so how much does it weigh
Old May 30, 2011 | 07:02 PM
lazlong's Avatar
Originally Posted by spoonfedcrx
If you strip it down to a real shell two people can pick it up with ease.[/IMG]
LOL! 2 of us picked the front of my old EF out of a ditch once. If 2 people can pick a shell up with ease it weighs way less than 700lbs.
Sancho815
Mar 22, 2011 05:04 AM
240sx crazy
19
Jun 5, 2005 05:28 PM
dmotoguy
Sep 1, 2003 04:48 AM
SloazzEKhatch
Jul 6, 2003 08:22 PM
617arg
Aug 30, 2001 07:24 PM
