Transmission code 16
Old May 27, 2011 | 05:59 AM
76 camaro car's Avatar
Default Transmission code 16
After replacing my timing belt on my 94 accord I got out my timing light to fine tune it. After running the jumper wire on the diagnostic wires my check engine light flashed a code 41 which is a oxygen sensor,but the D4 light kept flashing a code 16. What does that mean ? I remember about a year and a half ago twice in the same trip when I would take off from a stop I had to feather the gas pedal as the car seemed like it wanted to stall. The D4 light begain blinking then but after I shut the car off next time I started it and its ran fine and has ever since and there has been no blinking light. That was 30000 miles ago and never had the problem again. I would like to know what code 16 on the D4 light means though. Any help would be appreciated. Thanks
Old May 27, 2011 | 09:13 AM
Default Re: Transmission code 16
OK I did some checking and it says transmission code 16 refers to the linear solenoid or solenoid curcuit fault.Can someone shine some light on how I could check these ?
Old May 28, 2011 | 08:09 AM
poorman212's Avatar
Reset and see if it comes back. If so check the wire connectors to the solenoids, remove and clean.
rolledthatho
Dec 16, 2011 12:09 PM
theharlequin
Apr 13, 2004 12:00 PM
crxchris
Jul 18, 2003 03:51 PM
