Painting an EF, how much paint?
Old Sep 30, 2002 | 03:03 PM
technine's Avatar
Default Painting an EF, how much paint?
I am going be painting my Civic soon, but how much paint do I use and what techniques do you guys use when painting/preping to make the job smoother and better? Any tricks or tips?
I'm going to sand down the old faded factory paint, but not to the metal, just enough to get it uniform and even. Then I'll spray the primer, then spray the base coat, 2nd base coat and maybe a 3rd base coat and then clear.
How does that sound? Am I missing anything? I'm going to paint it championship white if it matters.
TIA
Old Sep 30, 2002 | 03:13 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default Re: Painting an EF, how much paint? (technine)
I think youll be fine with 2 gallons...and ps it will look like this when done
-Todd
[Modified by Count Blah, 12:14 AM 10/1/2002]
Old Sep 30, 2002 | 03:22 PM
SqueezinEF's Avatar
Default Re: Painting an EF, how much paint? (Count Blah)
Nice rims!!!
Old Sep 30, 2002 | 03:30 PM
Hcivic88's Avatar
Default Re: Painting an EF, how much paint? (SqueezinEF)
2 gallons?? i work at an automotive parts store, im pretty much the main paint mixer, and most people usually just use a gallon
Old Sep 30, 2002 | 03:42 PM
SOUTHCREX's Avatar
Default Re: Painting an EF, how much paint? (Hcivic88)
If your using a single stage paint then you wont need to clear coat, but if not then clear is needed. When sanding remember that primer will not fill anything smaller than 180g, your gonna wanna work your way up to at least 400, 400 or higher sand is ready to be painted.
Old Sep 30, 2002 | 04:13 PM
Brandon Chun's Avatar
Default Re: Painting an EF, how much paint? (TEAM GARAGE SHIFTDOWN)
Damn did you do that yourself?? Looks good
Old Sep 30, 2002 | 04:19 PM
technine's Avatar
Nice paint! What did you use, paint without clear or paint and then clear? I called the paint shop and they said 3 pints and need some activator. I think it was 1:1 1/2 paint to activator/reducer.
Any paint recomendations? And how much should I look to paying for primer/paint/activator/clear total? How much did you pay and what did you get.
Sorry for the many questions and thanks for the help.
4g4dcruisin
Paint and Body
11
Apr 26, 2009 01:07 PM
4g4dcruisin
Apr 20, 2009 02:28 PM
aalb1
Paint and Body
May 16, 2007 12:38 PM
technine
Oct 1, 2002 11:12 AM
