Dual Exhaust
Old Sep 30, 2002 | 02:22 PM
CRXTC69's Avatar
Default Dual Exhaust
Does dual exhaust cut down in horse power? What's better on a crx SI? HKS, Apexi, or Tanabe?
[Modified by CRXTC69, 11:48 PM 9/30/2002]
Old Sep 30, 2002 | 03:11 PM
bryant's Avatar
Default Re: Dual Exhaust (CRXTC69)
Duel exuast on 4 Cyl. =
Old Sep 30, 2002 | 03:17 PM
ijjz's Avatar
Default Re: Dual Exhaust (CR-X)
Quad exhausts on a 4 cyl though = (joking)
A rule of thumb I believe is that there should be one exhaust per header. Something like that, may be someone could correct me on this if its wrong.
Old Sep 30, 2002 | 03:22 PM
BDiddy's Avatar
Default Re: Dual Exhaust (ijjz)
Id say thats a good rule of thumb but my sisters 3KGT VR4 is a V6TT and it has 1 muffler and a resinator on the other side. Odd thing is that when I was looking for a system for it all I found was single exhausts with the exception of the Bozz Speed off-road system.
Take it for what its worth.
[Modified by BDiddy, 7:22 PM 9/30/2002]
Old Sep 30, 2002 | 03:29 PM
illusive's Avatar
You dont need a dual exhaust on a honda motor not enough back pressure there to make it worth anything. And also its just more weight on your car. For all show say if you had a black widow rear then maybe it would make sense to do dual exaust outside of that its a waste of money.
Old Sep 30, 2002 | 06:01 PM
pelotudo's Avatar
Default Re: Dual Exhaust (illusive)
Dual exhaust will end up hurting you. When I first got my B16a CRX (About a year ago), it had dual 4" tips on it; coming from a FloPro muffler (Made for a V8). I took it off and put on a canister, and it was MUCH better. The dual sounded like shiet too.
jB
Old Sep 30, 2002 | 06:03 PM
WuShu's Avatar
New User
Default Re: Dual Exhaust (PeloTudo AKA Gringo)
only thing your doing is weighing down your car.
Old Sep 30, 2002 | 06:23 PM
SiZ's Avatar
SiZ
Default Re: Dual Exhaust (HondaCRX)
The only problem with dual exhaust is the cost. Do you think Honda would put daul exhaust on of its fastest 4cyl car if it hurts performance?
Old Sep 30, 2002 | 06:26 PM
performula's Avatar
Default Re: Dual Exhaust (SiZ)
That's a Hi-Po engine though.
Old Sep 30, 2002 | 06:28 PM
performula's Avatar
Default Re: Dual Exhaust (performula)
If that's all true, no one would have a header. Exhaust would be blowing through the radiator.
[Modified by performula, 3:28 AM 10/1/2002]
pelotudo's Avatar
ROFL,
You're comparing a S2k engine vs a CRX Si...
Lets go ahead and add the rear wheel drive to this CRX while we're puttin on the dual exhaust.
jB
Old Sep 30, 2002 | 06:36 PM
.nate's Avatar
Your ignorance astounds me.
Old Sep 30, 2002 | 06:45 PM
altoid's Avatar
Default Re: Dual Exhaust (N8-T)
if you have enough exhaust coming out to merit a dual, then do it, if not don't worry about it
Old Sep 30, 2002 | 08:51 PM
getnasty's Avatar
Default Re: Dual Exhaust (altoid)
get two obx mufflers and run 2 3/4 and it helps and sounds great
Old Sep 30, 2002 | 09:08 PM
crx(gator)'s Avatar
thats not a true dual exhaust, that is a dual outlet muffler...
Old Sep 30, 2002 | 10:36 PM
TDRacing's Avatar
Default Re: Dual Exhaust (crxgator)
ijjz's right. there's no point to have one pipe that branches out into 2 when it gets to the back of the car. The stock S2000 might have 2, but the Spoon Sports and other Super Taikyu racing S2000s only have one. Makes you wonder.
Old Oct 1, 2002 | 07:14 AM
SiZ's Avatar
SiZ
What does the car being rear wheel drive have to do with it?!
I realize that the exhaust on an S2000 isn't a TRUE dual ehxaust so to speak, but it IS what he was talking about.
I do realize that there are better options on really high HP applications (race header) but I don't think you're going to lose HP with a dual exhaust.
Old Oct 1, 2002 | 08:11 AM
Brandon Chun's Avatar
Don't do it man, I'm sure the drivebility will be great around town and it'll sound good too tho
Old Oct 1, 2002 | 03:04 PM
DIY_Racing's Avatar
Its not a true dual exhaust.. most of those dual exhausts are for looks... If you added a dual exhaust were the pipe runs into a muffler that has two exits.. it wont hurt anything.. but if you took two of you headerpipes and ran that to a muffler, and the other two pipes to another muffler, that would be a DUAL exhaust system and the car would run like Toby from the Po po.
The S2000 isnt a TRUE dual exhaust. it goes from teh header, to one pipe, to a muffler with 2 exits..
whtever.. dumb thread.. just get an exhaust.. no big differences anywhere in horsepower.. just sound.. asnd looks.
Old Oct 1, 2002 | 04:44 PM
ijjz's Avatar
Default Re: Dual Exhaust (DIY_Racing)
Exactly, only thing worth getting an exhaust is so it can breathe. If you are looking for HP you might want to plop your money else where for now.
Old Oct 2, 2002 | 09:06 AM
Urban Business
Guest
Posts: n/a
another backpressure ****
HEH
y2kferari
Dec 6, 2006 11:43 AM
GapxGuy
Welding / Fabrication
10
Sep 21, 2005 07:17 PM
b18cEF9
25
Sep 18, 2005 07:29 PM
spooniq
Honda S2000
Sep 17, 2005 07:54 PM
eug_34
Jan 26, 2005 12:41 AM
