TiAL, Fluidampr, Skunk2, Sard, ITR, CTR
Please BUMP if viewed! Thanks!
The latest and greatest goods that I need to get rid of:
As of 6/14/11
B-series (GSR) Fluidampr Race Crank Pulley SOLD
Skunk2 Pro series front upper control arms for EG/DC. One has a brand new ball joint installed. SOLD
Brand new TiAL 38mm wastegate, large yellow spring, .7bar/10 psi SOLD
B16A2 crank w/ mains, flawless. SOLD
B16A2 (PR3) pistons and rods. SOLD
B-series Competition Clutch and pressure plate SOLD
B-series ACT Prolite 8.8 lb. flywheel.SOLD
Brand new JDM Stanley smoked sidemarkers w/ plugs and PWJDM wiring harnesses SOLD
B-series CTR N1 crank pulley. SOLD
Hydro LS trans, non-lsd. SOLD
SARD coolant breather tank SOLD
B18B1 (OBD2) LS long block. SOLD
OBD1 GSR head SOLD
OEM Honda window visors for EG hatch/coupe. SOLD
1st Gen. (86-89) Integra Energy Suspension Bushing Kit.SOLD
ITR solid aluminum trans brace.SOLD
Edelbrock Performer X Intake Manifold SOLD
As of 6/14/11
OBD1 GSR head SOLD
Ishihara Johnson GSR Teflon-Bladed Crank Scraper. Check here for more info: http://www.crank-scrapers.com/Honda-Acura_B-SERIES.html, $150 shipped
Autometer Gauges and other assorted happiness. $80 for everything shipped or separate prices listed below.
Water temp, brand new, never used, comes with wiring, fittings, etc.$35 shipped
Boost gauge, used, $25 shipped
Oil pressure, dial thingy fell off, I cant get cover off to fix it. Maybe you can. $15 shipped or free if you buy everything as a package.
Green LED replacement bulbs, $15 for all 3 shipped or $5 each.
Tilted gauge faces w/ mounting hardware, allows you to angle the gauges toward you for viewing. $15 shipped for all.
Seco B-series six puck clutch & pressure plate. Removed from LS block listed above. Holds fine, looks like a Competition Clutch knock off. $45 shipped
1994 Chevy S-10 factory service manual set. Practically brand new, barely used. I sold my S-10 years ago and have these taking up space on the shelf. Bought new from Helms for $200 and something. $75 shipped
P61 (OBD1 92-93 Integra GSR) ECU, chipped with ZIF socket and datalog header. Will run any engine that a P30 or P72 would. $100 shipped.
Tapped B16 oil pan, pickup, and windage tray. Make Offer
Additionally, I have several misc. OEM B-series parts stored so if you are looking for something in particular just ask.
Show me a link where you can buy it for that cheap shipped to your door and Ill consider going lower. I paid quite a bit more than what I am asking, granted it was a while back.
Shipping to Quebec will be expensive too, you are probably better off paying the $290
