97 civic ex instrument cluster problems
I have a 97 civic ex and the instrument cluster is messed up..none of the gauges work. some of the lights work like when i use the blinkers they work and the abs light is stuck on. i checked the fuses and that does not seem to be it.check engine light does not work also. recently i had some one work on the brakes and calipers and he says the reason the abs light is on is becasue the wrong steering knuckle is put in and the cable wont connect to that knuckle. would that prevent from the whole cluster not to work?? please help..open to all suggestions
utturkey
May 25, 2011 05:42 PM
PY 01-0972
Mar 17, 2005 12:29 AM
