Couple of questions in neptune
Hi..
I'm working on Neptune rtp for some time and I couldn't understand some stuff or I understood wrong..
Can you briefly explain what these are if u dont mind, please ?
1. What is "tip-in ignition corrections" ?
2. what is "ignition dwell" ?
3. what is "3-step settings" ?
4. what is "PWM" ?
Thanks in advance..
4. what is "PWM" ?
Thanks in advance..
I did it already.
Starts like this :
"The top section hosts all of the conditions necessary to activate TPS Tip-In Correction."
1. So what is "tip-in" correction ?
2. maybe I can understand ignition dwell stuff, maybe, ok.
3. 3-step settings :
"These settings are to setup your 2-step based on speed. You can also activate an output for use with an external 2-step such as the MSD."
So what is "2-step in this case" ?
4. there's no "PWM" in neptune help.
Starts like this :
I did it already.
Starts like this :
Starts like this :
2. Leave this alone if you don't understand completely. It's the ECUs way of compensating and preparing the coil to fire properly at various RPMs to achieve the correct timing and proper amount of spark.
3. A 2-step is a launch limiter set to a different RPM than your rev limit that can be activated multiple ways according to your settings.
4. Yes, there is... It's in the video section or on the website in the RTP video tutorials as well. PWM can be used with a MAC (or other) boost control solenoid to control your boost level.
jedubz
Aug 28, 2005 10:23 AM
