h22a no cells, no vtec
Old May 24, 2011 | 09:05 PM
enevel2099's Avatar
Default h22a no cells, no vtec
just swapped an h22a into my 94 accord. I am using a chipped ecu from rywire, my oil level is good, my vtec solenoid tested out ok. The car hits about 5500 then taps out. I have no check engine light or cells. I have reset the ecu and done some agressive driving as a precaution. What could be stopping vtec now?
Old May 25, 2011 | 05:26 AM
GhostAccord's Avatar
Default Re: h22a no cells, no vtec
What ECU and basemap did you order from Rywire? Does it hit a rev limit or just loose power at 5500?
Do you know anyone with an OBD1 P13, 93-95 SiVTEC Prelude ECU? that way you could try swapping out an OEM ECU and see if any CEL codes come up.
SkiiZ
May 2, 2010 06:37 AM
brucesi
Jul 21, 2006 09:33 PM
Chubs
Nov 14, 2002 07:28 PM
Acclude
Sep 11, 2002 10:30 PM
