Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
playing engine check light
Old May 24, 2011 | 05:46 PM
jasrams's Avatar
Default playing engine check light
SO my engine check light came on then went out tow day after then came back a day after then went out. when it came back i did a diagnostic and it is tell me the temperature not running at optimum level what does this mean anyone?
Old May 24, 2011 | 08:06 PM
MindBomber's Avatar
Default Re: playing engine check light
Do you have the exact code?
It sounds like you might need to replace your thermostat.
Old May 24, 2011 | 09:45 PM
It Wasn't Me's Avatar
Which "temperature" are you referring to? Intake Air Temperature? Engine Coolant Temperature? Or are you talking about one of the Heated Oxygen Sensors?
As MindBomber mentioned, knowing which code it was throwing would help. What you're saying doesn't make a whole lot of sense.
Old May 25, 2011 | 05:19 AM
jasrams's Avatar
ok going to get the code and tell you guys right away
98dxkoupe
Oct 2, 2018 04:32 PM
importdude2000
Jul 17, 2004 12:53 PM
UpstateCivic
Jun 7, 2003 12:27 PM
