Honda CR-V & Element 2WD & 4WD Element & CR-V
98 Crv AWD 5sp small project for now
Old May 24, 2011 | 04:37 PM
nathan8210's Avatar
Default 1999 AWD 5sp Build
New Project starts at the ending of page2
GSR Built 1999 White Awd 5sp CRV
GSR Built
Crower H Rods
JE Low Compression Pistons and new rings
Block Guard
Arp 1/2 thick bolts re-drilled head/block
Head rebuilt
Cleaned, resurfaced and valve job
Stainless Steel Valves
Skunk2 springs and retainers
New Valve guides and stems
Edelbrock Victor X Intake Manifold
New oil pan gasket, oil pump seal, water pump, tbelt, valve cover gaskets, tube seals, head gasket, distributor o-ring etc..
MSD External Coil
MSD Cap/Rotor/Wires
Greddy Oil Cooler
Exedy 3 Puck Clutch
Yonaka Cat Back Exhaust
Yonaka CRV Coilovers
S2000 Side markers
Front and Rear MudFlaps
EK4 Gauge Cluster
EG H-Brace
08 Civic Si Seats (Cut OEM brackets and welded on SI Seats)
AVS Window Visors
AVS Bug Deflector
EK Front Camber Kit (Doesn't correct camber and will give u more negative camber)
LED Interior Bulbs
LED Corner Light Bulbs and License Plate
Wheel ***** Had the Following with pics/specs;
16x7 Drag-16 45 offset 205/55/16
17x7 Acura Rsx Type S 215/45/17
17x7 Acura TSX 235/45/17
17x7 Acura ILX w/matching Spare 215/45/17
17x7 Honda Accord V6 6sp 215/50/17
15x6 Civic Hybrid 205/55/15
16x8 Enkei GTA Mesh 25 offset 205/50/16
17x8 Acura TL 215/45/17
17x8.25 XXR 537 25 offset 215/50/17
18x8.5 MB BATTLES 30 offset 215/40/18
Old May 25, 2011 | 02:24 PM
nathan8210's Avatar
MY V
Old May 25, 2011 | 07:53 PM
FreshxJDM's Avatar
Default Re: 98 Crv AWD 5sp small project for now
Nice V bro.. I like it ...
i have the same wheels on mine.
what spacers are you using in the front?
Old May 26, 2011 | 07:17 AM
nathan8210's Avatar
No spacers. Made the brake calipers thinner.
Old Project; 2011
Intake
Painted Valve Cover VHT-Wrinkle Red
2008 Civic Si wheels on Michelin 215/50/17 tires
Skunk 2 shift ****
Carbon Fiber Dash Kit
Alpine Deck with Ipod Connection
Boston Acoustics Speakers All around with tweeters
Oem Spoiler/Wing
Front and Rear Mudguards
Sport Side Trim
Sport Rear Trim
Fog Lights
Front Skid PlateJust added NeuSpeed Strut bar today...
Old May 26, 2011 | 02:57 PM
nathan8210's Avatar
I got my hands on an AEM Cold Air Intake. I could not fit my neuspeed strut bar on bcuz of the intake being in the way. Im either going to install a 2001 crv intake manifold (which is not as tall) or an Ls integra manifold.
So for anyone wanting to install a neuspeed strut bar and an intake, you cant for this year's model. Not sure what year the manifold changed. My guess is 97-98 b20b are tall and 99-01 b20z are lower
Old May 26, 2011 | 02:59 PM
nathan8210's Avatar
oh and by the way. The picture above shown with the strut bar installed, look closely at the intake by the throttle body. I could not install the intake all the way in.
Old May 26, 2011 | 08:02 PM
FreshxJDM's Avatar
Do you want to sell the neuspeed strut bar? if so, How much for it?
And how did you make the calipers thinner?
Old May 27, 2011 | 05:14 AM
qwrty's Avatar
is that strut bar for crv?? or civic/tegs??
thats allways the issue if you use a civic/teg strut bar, the b20 im
is always the issue....
Old May 27, 2011 | 05:24 AM
nathan8210's Avatar
NO, i just got the strut bar a few days ago. Im either installing a skunk2, LS, or b20z manifold.
I used an electric Die Grinder to shave off the caliper.
Old May 27, 2011 | 05:27 AM
nathan8210's Avatar
Its a Crv Strut Bar. It fits fine over the manifold. The problem is since the throttle body sits higher, the strut bar will hit the intake. Im going to swap out the manifold.
Old May 27, 2011 | 05:29 AM
nathan8210's Avatar
[QUOTE=qwrty;45351873]is that strut bar for crv?? or civic/tegs??
is always the issue....[/QUOTE
Ive had newer gen 1 crv's and they sit lower
Old May 27, 2011 | 07:33 AM
FreshxJDM's Avatar
Where did you get the NeuSpeed Strut bar from?
Old May 27, 2011 | 07:37 AM
FreshxJDM's Avatar
Never mind :p i found it
Old May 27, 2011 | 04:17 PM
JDMDrifter05's Avatar
Does anyone know if someone makes a rear strut brace or if one from a different honda will work and any other front strut braces beside the neuspeed
Old May 27, 2011 | 04:44 PM
nathan8210's Avatar
If u have the lower intake manifold, yes others will work. Ill research the rear strut bar cuz I want one too.
Old May 28, 2011 | 01:03 PM
nathan8210's Avatar
Today I added a Acura Tsx Spare Tire
Replaced my 215/50/17 with 225/55/17 which looooks alot better
And Adjusted my Valves (b20's are known to fail if valves are not adjusted frequently)
Old Jun 1, 2011 | 03:17 AM
rockwell's Avatar
thats great sounds good......
Old Jun 1, 2011 | 05:29 AM
vtecn8ive's Avatar
I'll have a rare Honda Access map light / sunglass holder if interested...
Otherwise good stuff!
Old Jun 1, 2011 | 03:28 PM
nathan8210's Avatar
If its the one im thinking of not really interested. Post some pics please.
Old Jun 1, 2011 | 03:31 PM
nathan8210's Avatar
Just installed some 2003 Acura Tl Type S wheels. I was surprised on how good they looked. Like them better then the Si wheels.
Old Jun 1, 2011 | 04:00 PM
nathan8210's Avatar
My V on other wheels
Old Jun 2, 2011 | 07:53 PM
nathan8210's Avatar
Selling my aem cold air intake
Mariomanzano@msn.com
Old Jun 3, 2011 | 03:55 PM
nathan8210's Avatar
Added 5th Type S wheel spare
Old Jun 5, 2011 | 02:06 PM
nathan8210's Avatar
our spares
Old Jun 5, 2011 | 05:48 PM
nightscream's Avatar
What kind of gas mileage are you getting? done any towing with it? Thinking about getting 1 in the future. Trying to do some research...
