has any one DIY a garage/work area
Old May 23, 2011 | 02:01 PM
cibao2ner's Avatar
Default has any one DIY a garage/work area
ive been looking around, home depot, loews and was wondering how hard is it to make your own garage...there metal ones tha are sold for around 2k....but was wondering what other options are there? any pics and info on where you got yours and price...
Old May 23, 2011 | 02:13 PM
k24em2's Avatar
Default Re: has any one DIY a garage/work area
Nails and wood
Old May 23, 2011 | 02:45 PM
cibao2ner's Avatar
i need a permit in my area and a drawn plan....so nails and wood wont do it..
Old May 24, 2011 | 12:06 AM
RickyLee53's Avatar
I'd imagine they would be ok. Not that populat over here in the UK we normally use concrete sectional.
Remember though, the base might cost you more than actual building.
Old May 24, 2011 | 05:06 AM
WhiteSlips's Avatar
Steel buildings aren't that expensive, but like the guy above said the concrete base is what costs a lot. If you are okay with gravel, you could always dig a hole under each post, run some long threaded rod in to the hole and fill it with quikrete. When the quikrete dries the threaded rod with a washer and nut on top will hold the garage down. Lay down some weed barrier and pea gravel for the floor and you should be good to go.
Old May 25, 2011 | 11:50 AM
JDL Tuning's Avatar
I don't know about having gravel on the floor??? That does not sound very safe if you have to jack up a vehicle. I would not wanna be underneath it....
Josh
Old May 26, 2011 | 04:01 AM
JDMCRX's Avatar
Find a friend that knows a little bit about concrete to give you some advise.
Look around for a steel building. I know here in canada Home depot and Lowes and Homehardware have garage kits.
Ill find the link i think its garage plans .com or something that have complete blue prints for garages and there is over 60 plus designs to chose from. There cheap $100-200 bucks and it list everything from the nails to the shingles to the TEE.
Also comes with blue prints of the cement pad.
Cement is not that exspensive. Its the Prep time that exspensive or time involved.
Honestly find a plan you like go to your city hall ask for a permit $100-200 bucks then start digging with a shovel and some buddies. Monolythic cement pad only has to be dug down 12" then crushed stone and compact it down and what not.
Or if thats not in your budget at the momment.
Find a plan of what you would like. Do the pad and toss on there a car shelter on the pad for the time being. You could have a nice work place for under $2,000 bucks.
JDMCRX's Avatar
BTW check out garagejournal forum for some good ideas man.
Here is my garage build i did last year. Gives you some ideas on how much work is involved.
http://www.garagejournal.com/forum/s...ad.php?t=68337
fatpride111
Jul 7, 2008 08:20 AM
AB16A2T
Mar 31, 2002 09:33 AM
Art Vandeleigh
Jan 26, 2002 12:23 AM
