no spark b17a swap
ok so i swaped in a b17a out of a 92 gsr in my 90 si hatch. no spark, new cap and rotor. coil has power, injectors signal wire pulses (other stays hot). all grounds check (tranny, vc, thermostat) cel coming on for 2 sec. then goes out. fuel pump priming. tested the icm (igniter) at shop and good. i am using a obd0 -obd1 ecu jumper from ebay. wired all dizzy wires color for color except white wire that is not sheilded to yellow green. Dizzy and ecu and injectors are for the motor. obd1
the motor was sitting for about 7-8 years, so far all the injectors o rings replaced due to leaking. i know the motor is good. i pulled it out of the RUNNING car 7 or 8 years ago. just took a while to get everything. lol
turbogrs
15
Oct 13, 2010 09:42 PM
spiceisler
Jul 30, 2005 01:11 AM
Renegade
Oct 30, 2003 07:22 AM
