DC2 98 spec Type R swap Help
Old May 23, 2011 | 11:52 AM
Murph88's Avatar
Default DC2 98 spec Type R swap Help
So my buddy swapped a 98 spec type R into his integra and is having some issues and is looking for some incite. He claims he cant access the ecu because it is jdm. The first issue is it is idling at about 1500rpm, is this normal? Second issue and more concerning to him is that it doesnt seem to be engaging into vtec... is the type r crossover just not as pronounced as others? Vtec solonoid? Faulty wiring? If anyone has any suggestions or knowledge about this it would be greatly appreciated.
Old May 23, 2011 | 03:23 PM
Just a n00b's Avatar
Accident Prone
Default Re: DC2 98 spec Type R swap Help
1500 idle is ridiculously high.
Crossover is VERY pronounced.
Might have better luck in the swaps forum.
Old May 23, 2011 | 03:32 PM
97CWITR's Avatar
Post in Hybrid section.
Lock.
Old May 24, 2011 | 10:40 AM
(. )( .)'s Avatar
Is a Check Engine Light on? What vehicle is this R engine into? Was the engine and computer working befer the transplant?
Old May 24, 2011 | 10:45 AM
racebum's Avatar
is the engine COLD?
1500rpms is normal on startup and vtec doesn't work until the engine is warm
the idle should drop to around 750 when the car is warm, then you set ignition timing with the jumper jumped and will be ready to drive.
don't rail on the car before you set ignition timing!
Coopa B18c5
Jun 9, 2013 12:26 AM
salmaan
Sep 24, 2010 08:03 AM
JDMDC2-209
Feb 5, 2008 07:52 PM
4wsB21a
Feb 12, 2002 07:24 AM
