fuel system problem, but not the main relay
Old May 23, 2011 | 10:47 AM
qcextreme's Avatar
Default fuel system problem, but not the main relay
Basically I have the same symptoms of a bad main relay, 1994 honda accord 2 door EX... its acts like main relay is bad, but I put a brand new oem main relay from honda in it. Also a brand new ignition switch and the fuel pump still won't prime right a way. it doesn't matter if its hot or cold outside it does it almost every time you turn the key. Basically if you turn the key to the on position with all the lights on but the check engine light doesn't go off , I have to leave it there for a while, some times 3 mins, some times it takes 30 mins. then the check light goes off and the fuel pump will prime then it starts up and runs great. When started and running she drives like a new 1, no problem at all. Any ideas, what's my next step. I'm thinking fuel filter, maybe fuel pump, maybe ecu.
Old May 23, 2011 | 10:50 AM
qcextreme's Avatar
Default Re: fuel system problem, but not the main relay
The check engine light acts just like a main relay problem. When it goes off the fuel pump primes and she drives great
jerome^galon
Jan 4, 2012 07:03 PM
PatrickFrantz
Aug 21, 2008 05:53 AM
JDM_FATBOY
13
Nov 12, 2007 07:33 AM
90AcuraIntegra04
Jan 6, 2006 05:41 PM
