Blox Comp B vs. Buddy Club 3's
Which cam could I benefit more from on a all motor set up?
My setup is
Eagle H-beam LS rods w/arp bolts
RS Machine 84.5mm ITR pistons
B16b head with minor port/polish
Skunk2 cam gears
Skunk2 titanium retainers
GSR water pump
GSR oil pump
Arp GSR head studs
GSR Timing belt
JDM ITR 4-1 Header
Hondata S200 on P28 ecu.
2000 Civic SI transmission
Skunk2 Pro Series Intake with BBK 70mm tb
RC 550's and will be tuned on e85.
My setup is
Skunk2 cam gears
GSR water pump
GSR oil pump
Arp GSR head studs
GSR Timing belt
JDM ITR 4-1 Header
why dont you spend and extra 100$ and get supertech dual valve springs AND retainers? with semi big cams it would be much less stress on those b16 springs i would think??
bloxs cams do pretty well. I've actually installed a set of the "B" in a b18c1 engine. If i could take a picture of his dyno sheet he sent me i would post it for you. he gained 12whp. But honestly both are good cams bloxs and buddy club. Good luck..
Na-Spirit
29
Sep 8, 2010 11:40 AM
