CODE 15- CAR WONT RUN WHAT DO TO
yesterday my car started running and stumbling, All the sudden i get code 15
Ignition output signal?
Car died on side of road i have to go make some sort of attempt.
The Main relay box is clicking as well.
Can anyone help me?
Can anyone help me?
I have a OEM honda manual which is like 4000 pages long that should cover it.
I only came to this site to get a quick fast response and i guess that day and age is over. I do have spare honda parts laying around. I will try the distributor. I do want to try all the tests but w.e. Ill just put on my other dist. I also do have a small White box that goes inside the dist. when i purchased it i had Code 9. and was told that the white box may fix it. I thing that my be a ICM. IDONT KNOW. THIS HAPPNED BEfore AND BLEW MY ECU.
Dont want another fried computer, and have the hassle of trying to source another P30 ECU.
I read a little will try basic cotinuity tests. and than if nothing i will put on my other distributor. I got BOTH code 9 with same series but difrent dist. I have a OEM td44u and a cheap piece of crap off ebay that has worked up untill now. I gues i will switch over to the oem td44u but what im sayin is i will always have the code 9, and code 15 started yesterday.
Hmmm I had the same problem. I deliver pizza and was on my way to the house to drop off the pizza. When my car lost all power and died. I thought it was gas issue since I was low. But I saw that it was throwthrowing the code 15. I took apart the dizzy andtook it off the motor. I didn't see any problem till I took it off the motor. The person before me had put a new dizzy on and didn't plug in 1 plug all the way. It fell out, so Isaac no getting spark. Check around your dizzy. Take it all the way off the motor, and takethe cap rotor and all off. You just might not be seeing something. And check any wires you might have toyed with
kamakaze1
Jul 28, 2006 11:06 AM
