D16 fuel rail and injectors question
Old May 21, 2011 | 05:50 PM
AlfieRoach's Avatar
Default D16 fuel rail and injectors question
So if you have a d16z6 usdm intake manifold going into a 89 si civic hb, and it already has a mpfi d16a6 swap. But your doing a complete swap can you use the obd 0 injectors and fuel rail from the a6 into the z6? and still be able to get ref'd? and also would a a6 crank pulley work on a z6? and would a d16a6 exhaust manifold fit a z6?
Old May 26, 2011 | 12:03 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: D16 fuel rail and injectors question
Use the a6 injectors in the z6 mani, and don't mess with the wiring for the injectors.
If you use the z6 injectors, the clips are different and you have to deal with removing your resistor box.
It is FAR easier to just use the a6 injectors. I don't believe you even need to mess with your fuel rail at all. The z6 fuel rail will work with the a6 injectors.
The ref side of things, I am not terribly clear on. I think the main idea is that all the stock components must be used on the manifold, which may mean some wiring extensions.
The a6 crank pulley will work on the z6. and the a6 exhaust manifold will fit as well to the z6.
Old May 26, 2011 | 05:32 PM
AlfieRoach's Avatar
cool so injectors now how do i ID the differences between a6 and z6
Old May 26, 2011 | 08:23 PM
BiGZ's Avatar
With an Ohm meter...
Aquila
May 30, 2016 12:53 PM
FeRReTTi
Jun 13, 2015 11:20 AM
AlfieRoach
Jul 20, 2011 03:18 PM
leroyb
Jun 19, 2009 12:13 PM
iphatcrxi
Nov 14, 2006 10:09 AM
