BMC Manifolds now Gauranteed to 75psi
http://www.youtube.com/watch?v=jIL6EJ7EQ9Q
We had just did a 5 minute test and the pressure leaked down from 75 psi to 40psi. The leak was in the fittings, not the manifold itself. NPT fittings apparently don't seal up as nicely as AN fittings.
BMC Stepping up to the challenge!
From now on all manifolds that leave the shop will be pressure tested.
Please ignore our hick voices. It is the heart that counts.
The shop mascot came to give us support.
Working late on a Saturday. We didn't leave the shop till 6.
Machining dummy injectors for sealing up the manifold
Just what the Honda Commuity is lacking 9/10th's of the time "Customer service!"
BMC stepping up and improving on an already worthy product. We need more of this on the daily. Happy to be one of your customers!!
so.....i may be dumb....but doesn't the amount of volume a certain turbo flows at a certain PSI skew this test?
IE....30psi on a 62mm verses 30 psi on a gt4272
Good stuff
Why not simulate a nitrous backfire as well? What are you trying to learn by hitting one with 125psi of sustained pressure? I would imagine it would probably warp some and if it explodes or comes apart it would be pretty dangerous for whoever is doing the test.
Very nice James!! Thanks for taking care of my manifold and then some without any hassle! The very best customer service I have ever delt with EVER! Im glad I stuck it out with ya.
Good stuff
He's doing it in the enclosed CNC, if he keeps the doors shut, he should be fine.
Personally, I'd seal it up completely, and hit it with whatever I have available in terms of air pressure and see where the weak links are.
Either way, any testing is better than none, and as a current owner of one of these manifolds that has broken, the more testing the better..
Either way, any testing is better than none, and as a current owner of one of these manifolds that has broken, the more testing the better.. Good stuff
to BMC... Stand up company. And I dont even have their stuff.
