Bad shaking in front end...
Old May 21, 2011 | 04:13 PM
cj90si's Avatar
Default Bad shaking in front end...
I have this bad shaking in the front end. So I jacked up the car and spun the wheels by hand. The driver side spins just fine. The passenger side spins maybe once then stops. I pulled the wheels off and pulled the hubs. The bearings seem fine and so do the axles. I put the ps wheel back on without the rotor and caliper. Spun the wheel again and it spun great. But the shaking stops when I turn to the right, even just slightly. Any help or other suggestions on anything else to check would be greatly appreciated. Oh and forgot to mention have to fight to get into gear and there is no fourth gear at all. Could something in the tranny be causing the shaking as well????
Old May 26, 2011 | 12:06 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Bad shaking in front end...
ah, yeah. if your transmission is missing a gear, i would bet the shaking issue is coming from your transmission. you should probably stop driving the car until you can figure out what is wrong with the transmission, otherwise you risk doing more damage.
Old May 26, 2011 | 12:21 PM
Tyson's Avatar
sounds familiar.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-crx-brake-issues-2940211/
wgbm92
May 21, 2011 02:03 PM
mr.jamrock
Sep 6, 2009 04:55 PM
civic89si666
26
Feb 7, 2008 10:33 AM
Sean @ ESG
18
Dec 2, 2005 06:14 PM
DumpedSi
Jul 26, 2003 03:06 PM
