CT All Motor 2000 Integra GSR
It has been sitting in my drive way under a cover for over 2 years now and due to military obligations it just doesnt get driven. Its time to part ways I am afraid. She has been babied her whole life.
Asking 7k OBO
2000 Acura Integra GSR
Deep Violet Purple
60000 miles chasis
Complete Motor Rebuild engine has 4000 miles on the block w/ Original head. New bearing, rings, water pump, and oil pump.
Engine
JDM ITR Bottom blockb18c
GSR head b18c1
Full Port and Polish
Flat top valves
Toda valve springs
Toda spec b cams
Toda adjustable cam gears
Kevlar timing belt
Skunk 2 intake manifold
Big bore throttle body
Upgraded injectors
Samco radiator hoses
Urethane engine mounts
Yellow powder coat valve cover
Carbon Fiber spark plug cover
Grounding kit
Upgrades spark plug wires
BP flow stake intake filter with short ram
Aem fuel rail
Fuel pressure riser
Spoon Radiator cap
Spoon oil cover
Spoon Drain plugs
Spoon thermostat
Spoon fan switch
JDM ITR headers
Carsound high flow cat
Tanabe super racing medallion b pipe and muffler
Hondata S200 (dyno tuned)
OBD1 ECU chipped
ARP Head Studs
Suspension
Eibach Sport line 1.8” Lowering springs
Tokiko 3 way adjustable shocks
Slipstream 16” rims
Carbotech brake pads
Spoon rear and fwd upper tower braces
JDM ITR rear lower sway bar
Urethane rear lower sway bar bushings
Tenzo rear lower sway bar
ITR trunk sway bar
Transmission
Exedy organic clutch
Spoon LSD
ATS 4.9 final drive
JDM ITR first gear
Urethane shift linkage and short throw shifter
Interior
2 gauge cluster w/ oil pressure and water temperature (autometer carbonfiber)
Spoon shift ****
Driver 4 point driving harness
Various ITR interior parts
I will take some more pictures tomorrow.
Asking 7k OBO
Deep Violet Purple
60000 miles chasis
Engine
GSR head b18c1
Flat top valves
Toda valve springs
Toda spec b cams
Kevlar timing belt
Upgraded injectors
Grounding kit
Aem fuel rail
Fuel pressure riser
Spoon Radiator cap
Spoon oil cover
Spoon Drain plugs
Spoon thermostat
Spoon fan switch
JDM ITR headers
OBD1 ECU chipped
ARP Head Studs
Suspension
Slipstream 16” rims
ITR trunk sway bar
Transmission
Spoon LSD
ATS 4.9 final drive
JDM ITR first gear
Interior
Spoon shift ****
- LoL - db8
Feb 15, 2006 04:56 PM
